About to spend some money on a spraying system and would like to get into HVLP. Need suggestion on a system that could spray light bodied solvent based sealer for house spraying application, and would eventually be used for lacquer and other furniture finishes. Does a system exist???? I’m thinking $500-$700. I’ve been pointed toward airless for the House application, and conversion for the furniture application but don’t want a collection of incompatible systems. Would love to hear someone’s experiences good or bad…..
Bob
Bob,
Check out http://www.homesteadfinishing.com, Jeff Jewitt's website. You can browse/search his only forum and find all the information you need to make the right decision.
Good Luck
Terry
Delray Beach, FL
For painting houses, airless is the way to go. You say you want to spray a "light bodied solvent based sealer for house spraying application" but I'm not sure what that means - trimwork? sealing log cabins? sealing cedar shakes? decks? If you're talking about spraying the entire exterior of a house, an airless system is your best choice. Anything else, like HVLP, will take 10 times longer. Airless is not a good choice for furniture/cabinetry finishing though.
There is a very good gravity feed HVLP conversion spray gun made by Star that costs under $100. If you go to this link, you can read a lengthy discussion about the spray gun - http://www.woodweb.com/cgi-bin/forums/finishing.pl?read=141662 - If you do visit Jeff Jewitt's web site, look on his Q&A board - someone asked about the Star, and Jeff said he bought one himself and it's a good spray gun. This spray gun is a good choice for furniture finishing.
If you have a compressor, you can get the airless for the big jobs and the HVLP spray gun both for your budget amount.
Paul
F'burg, VA
I RECIENTLY BOUGHT A HVLP 4 TURBINE SPRAYER. I LIKE THE PORTABILITY OF IT. I ALSO LIKE THE FINISH I RECIEVED. I ALSO SPRAY LATEX WITH IT. I FOUND IT TO BE OVERKILL FOR THE LAQUOR & TO SLOW FOR LATEX. IF I COULD BACK UP, I WOULD BUY A CONVERSION UNIT & A AIRLESS UNIT. I TRIED A VERY INEXPENSIVE CONVERSION SPRAYER WITH A GRAVITY CUP AND WAS VERY IMPRESSED, JUST DONT BUY ONE WITH PLASTIC PARTS. UNDER 100$ SHOULD DO YOU NICSLY. HAPPY SPRAYING
