here are two quick questions.
When someone says IMO what is that?
Also could someone explain ‘morse taper’
blessings
derek
blessings
derek
In my opinion.
A morse taper refers to the tapered shank of certain rotating tools and the accompanying socket into which they fit; such as on lathe centers and many industrial drill presses and milling machines. Morse refers to a specific set of dimensions and are called out as #1, #2, etc. I think there are other taper standards out there but Morse is most common (?).
A tapered shank can be popped into the socket with a tap and hold well. This system is also self-centering by nature.
In My Opinion IMO means in my opinion.
Who ever invented work didn't know how to fish....
IMO (in my opinion) in a post is superfluous. Of course the poster is giving their own opinion, they would hardly be quoting someone else's opinion, would they?
Ideally on the front page of every forum there would be an announcement "please understand that all opinions given here are those of the individual posters". Then there would be no need for people to keep saying IMO
All the above IMO, BTW
John
Maybe they have a split personality and it's the other side talkin!!
IMO - In my opinion
IMHO - In my honest opinon (different from the one above)
LMAO - Laughing my A-- off
ROFLMAO - Rolling on floor, laughing my A-- off (lots of that around here)
You may also encounter IMHO, in my HUMBLE opinion, which means "if you don't agree with me please don't beat me up over it!"
Google for
"morse taper" dimensions
and you should get several sites that list the sizes. Fiddle with the search string and you may find a site that explains self holding and self releasing tapers. Morse tapers are self holding tapers.
Morse taper (and other self holding tapers) are how 19th C. machinists held drills concentrically in machine tools before we had the technology to build good quality, cheap, self centering drill chucks.
Derek, Morse tapers usualy on lathes. Jacobs on drill presses & drill chucks
Brown and Sharpe (B&S) I forget? Stein.
Edited 11/29/2003 5:47:38 AM ET by steinmetz
There are two tapers on a lot of drill presses so they take an adapter with two male ends to install the chuck. AFAIK, all the taper mount drill chucks sold in the US use a Jacobs tapers. All the drill presses I've seen that use this technique have Morse taper holes in the spindle. So the adapter is a male Jacobs taper on one end and a male Morse taper on the other.
(More than you wanted to know about chucks: Not all chucks are taper mounted. You can get chucks that are thread mounted, with a tapped hole in the back of the chuck. I believe most hand held drills use thread mounted chucks. You can also get chucks with integral adapters, so the adapter is part of the same piece of metal as the back of the chuck. The ones I have seen in catalogs, the adapter shank is either cylindrical or Morse taper. The only maker I know of is Albrecht, and their chucks are way expensive. Christmas is coming up, and my birthday is in June. Keep me in mind if you're feeling generous. Or profligate.)
Morse tapers certainly became more popular than Browne and Sharp. Other than machines manufactured by B&S, the only application I know of is that some dividing head spindles are B&S taper.
