I am building a coffee table, where the top opens up in the center to expose a box below. The client wants the top to slide on drawer slides with magnets holding in the closed position. The two ends will have bread boards, but where it splits in the center, the board meet end grain to end grain. My question is: how do I control movement in the center of the table top where it meets with the other top piece???
Could you make some kind of a ship lap joint or other ?
dusty
Maybe I am misinterpreting your question, but could you anchor the breadboard on the end of the center joint, therefore allowing any expansion to show at the outside corners?
Alan - planesaw
Alan,
They want the top to run the length of the table, with a 3" board on each end and one one each along the length of the top. In the center, where it will open and slide apart, they want the boards butting end to end without any boarder.
Dean - marquetry
Perhaps I have misunderstood you, but I would be far more worried about tying the width of the sliding halves to drawer slides with any chance there of expansion and contraction. If this must be done then I would go the laminboard and veneer route to eliminate movement.
Mufti,
I think you hit it right on the head!
They wanted it out of Oak, and it never crossed my mind to use MDF of Baltic Birch and cover with Veneer. I think I'll go with Baltic Birch as the screws for the drawer slides will hold better than using MDF as a substrate.
Thank you, I knew if I stated the problem one of you experts would come up with a great solution.
Marquetry
Becauase of the drawer slides (I've NO idea how they are installed in this situation) and catch in the middle, won't all wood movement be directed to the outsides of the top? Of course each half still has the issue of the breadboard, but how wide is half of a coffee table? Mabye a fender joint on outside edges where top meets breadboard and only inside tenons glued? I just don't see how the center joint is "the" issue; is it?
Brian
Dean,
I would attach a batten to the underside. If it will interfere with the sliding peration, rout a recess in the underside of the tabletop to allow the batten to sit flush with the surface (bottom).
