I was thinking.. Gets me in trouble..
Anybody in here ever use a power feeder on a bandsaw for resawing large boards?
My 18″ Rickon cuts straight and true BUT the blade teeth leave marks at variable distances as I cut..
Many areas are free of any tooth marks but then I see several.. Then OK fer’ awhile.. I think it is inconsistent feed rate.. Hell, I’m old and have to shift positions to keep my balance….
I am sure it is ME and not the blade or saw.. I think! LOL
Anybody do it and have a picture of their setup?
Never used one but I saw one last year at the Milan trade fair, great set up, it would even cut veneer on a 70 cm bandsaw.
Philip
70 cm bandsaw Is THAT a BIG one? USA here...
Edit just funnin ya sort of.. Lookin fer my Centirmeter ruller!
Thanks but I have no helpers.. But I understand what you said!
Edited 5/25/2005 5:50 pm ET by Will George
Edited 5/25/2005 5:54 pm ET by Will George
2.54 cm to the inch
1.057 quarts per litre (liter)
39.37 inches to the meter (metre)
2.2 lbs per kg
454 grams per lbI learned these conversions in the 6th grade (1973ish) Not far from the time Gerry Ford signed the "Metric Conversion Act of 1975" http://lamar.colostate.edu/~hillger/history.htmMark
I learned these conversions in the 6th grade ..
Me too! I started likin' girls!
I remember there being two advertised in the Grizzly Catalog. I couldn't find find them on the website, but if I remember correctly, one was fairly small, the other seemed fairly substantial. It would certainly be an add-on that would improve consistency.
Will,
We have a dedicated 28" Laguna set up with one-inch carbide-tipped blades and a variable-speed power feeder for resawing at school. I use it, or supervise its use, several times each week, and it works like a dream - as long as:
This is a college woodworking environment, and we require two-person teams when operating this saw; this is particularly important at the beginning and end of the cut when one person controls the stock, and their partner engages and releases the power feeder.
As you suggest, rate of feed is crucial to acheive consistent results. Be especially careful at the end of the cut to ensure the wheel of the power feeder doesn't torque the work out-of-parallel with the fence, and the operator's hands are clear of the blade.
I'll see if I can find a photograph to post later.
-Jazzdogg-
