I would like to make a shooting board .
Does any one out there have
any plans for a shooting board?
Like what is the best wood to use
and where do I start . . .
I don’t have any power tools
only a Jap saw and a hand
plane.
Any comments, ideas, or thoughts
appreciated
mikeybabe,
Here are a set of plans I downloaded some time ago...
Thankyou BIG GUY,
Or what ever BG stands for ?
I have poured over your plans
and will finds parts of it very useful
THANKYOU,
Ciao,
Here's a collection of links to shooting board stuff I've bookmarked over time. I think only a couple have actual plans but there is good info on all I think.
http://www.amgron.clara.net/planingpoints/rampedboard/rampindex.htm
http://www.sydnassloot.com/bbuckner/MitrePlane.htm
http://www.hntgordon.com.au/jointinglongboards.htm
http://www.sawmillcreek.org/showthread.php?t=28659
http://www.amgron.clara.net/planingpoints/shuteingboards/shuteingindex.htm
http://www.cornishworkshop.co.uk/shootingboards.html
If you build it he will come.
Thankyou Douglas 2 cats 3 cats 4 cats ,
Your just a wealth of information. I was
looking on the internet for this kind of info
and do you think I could find anything?
THANKYOU AGAIN this is a good start for me
Douglas:
I saw your message about shooting boards and liked the one at the cornishworkshop. I do have a question though.
When shooting miters how is the triangular jig attached to the fixture?
I like the logic of this board and the info at that site and decided to build one.
Thanks in advance for your help.
David
Wish I could help but bookmarking a bunch of them and making them is 2 different critters:-) The only ones I've managed to do so far is one for putting bevels on the long edges of boards and a real small one for block plane use doing angled pieces on small inlay segments. I'm sure someone here knows the answer though.
David
I think that you are referring to my ramped shooting board (with add on mitre fence).
When I built this originally, it was made with a fixed straight fence. About a year ago I modified this to use an adjustable fence. The advantage is obvious - it can be fine tuned when necessary. (See bottom left picture - this one, too, has been replaced with a nicer looking fence - see picture below).
You can see the hole in the fence to which the mitre fence is added. This is also evident in the top right hand picture. The advantage of this connection is that the mitre fence may also be adjusted slightly (other types of fences are attached to the base of the board with dowels, but this means that they cannot be adjusted).
Hope this helps.
Edited 3/13/2007 9:20 am ET by derekcohen
Derek:
Thanks for your informed reply. The question I still have though is do you secure the triangular fixture used for shooting mitres on to the jig or do you just rest it against the straight fence?
I am going to incorporate the finely adjustable 90 degree fence as I have seen you reply to in the past.
Thanks again,
David in Cleveland Ohio
David
The mitre fence is attached with a bolt (that is set into the mitre fence) that runs through the straight fence (which is attached permanently), and then clamped tightly with a butterfly nut.
BG and MB, I just wandered in. THanks for the links BG. After reading several of the articles I learned why the shooting board does not get cut away while shooting http://www.cornishworkshop.co.uk/shootingboards.html and that a cramping block is used with a cramp (UK word for clamp and clamping block-HA!) http://www.amgron.clara.net/planingpoints/shuteingboards/shuteingindex.htm.
Dang, the things I learn fro you guys- thanks for the links they were very informative.
KB
Hey Keef,
That Cornish Workshop was a veritable
source of information hey . . . I was there
for ages checking it all out. Can you believe
I want to make a workbench and then when
I finish the workbench I want to make a
Cello (laughs) . . . WHY AM I LAUGHING
I'm deadly serious. I'll be scraping away
for years working my fingers to the bone he he.
I'm so excited I can finally get a lump of timber
square on all sides now using just a hand plane
So now I think I'm hot stuff he he.
Ciao,
Here is another link. I note that the connection from Alf's website to mine is not active.
http://www.wkfinetools.com/contrib/dCohen/z_art/shootBoard/index.asp
It is now. If you don't tell me, Derek, chances are I won't know... Same goes with the rest of the site - it's pretty external link-intensive so if anyone finds a dud, please do let me know.Cheers, AlfP.S. Glad you enjoyed it, Mikeybabe - brings a warm glow, that does :)
Hi Derek,
You shouldn't have sent me
that link I spent most of my time
drooooling over the Marcou Planes.
I want one badly. And I thought
My Clifton and Lie Nielsen planes
were great ? Goes to show there
is always something better around
the corner.
Ciao,
MB,
I'm laughing too cause I have a workbench in process and my "Make your own guitar" book just arrived. Great aspirations. I do believe that a Cello is several orders of magnitude (100x at least) more complex than a flat top acoustic guitar.
What bench design are you looking at? WHat kind of vises?
KB
Hey Keef,
I'm making a bench of my own design
I'm afraid it isn't very practical. But it's
beautiful and functional for how I like to
work. I'm making it out of Western
Australian Jarrah of which I am laminating
the pieces together so I end up with
a bench 3 meters long the legs being 15cms
thick and 42 cms wide to accomodate
a Lie Neilsen quick release vise. Of which
I am having the handle turned in Jarrah
instead of the traditional maple.
I'll send you a picture of the plan if you like
I have it on my lap top somewhere. The
bench is in 5 pieces and it bolts together
through the top with brass pins and the
legs are held in place with wooden pegs.
It looks like something out of stone henge.
And can double up as a side board in the
house if I'm not using it.
As for the Cello. I have a female friend
that plays at the con and I'm going to use
hers as a pattern.
Apparently you need moulds for the so I'll
research that when I finish my bench in
a years time (laugh) Wish there were more
hours in the day. Working and trying to do
projects gets to be a bit of a drag.
I'm getting confused as to who everyone is
your MB right?
Yes, send me the plan when you have a minute. Actually Mikeybabe, you're MB, I'm KB- KB and everything else without numbers, I post as Keef.
I didn't know that Lie Nielsen sold vise hardware- but sure enough they do. Wonder if they have a LN mark on them anywhere (for bragging rights)?
Having read through the just-arrived Guitar making book, I'm again choking on the idea.
KB
All the acronyms get confusing ,
And what kind of snobbery could possibly
be attached to any kind of woodworking vice hey . . .
I spend most of my time finding ways to hide it.
Here's that plan as promised. Sorry I can't say more
I'm off to the movies talk to you soon.
Mikeybabe
