All,
I’m in need of some clever ideas for storing pipe clamps on the wall, instead of on the floor. All of my clamps are 6′ long (continuous pipe, not coupled) so I’d like to store them vertically vs. horizontally on the wall since I don’t have alot of additional wall space horizontally. My garage is unfinished so that may give a few more options, e.g. between studs or even hung from the ceiling joists. Any photos would be helpful as well.
Brett
Something like the attached image is fairly standard. You want to space the "teeth" far enough apart that two clamps in adjacent slots clear each other, but not so far apart that there's a risk that a clamp could fall through. 3/4"-thick teeth spaced 2-1/4" center to center is about right for standard Jorgensen pipe clamps.
If you make the teeth longer than shown, you can store your clamps two per space (or even more, although you obviously reach a point where there's a risk that the whole thing is going to come crashing down from the sheer weight).
Hi Brett,
Well, I'm not sure how clever it is :) but this has worked for me. They hold a surprising amount of weight.
Paul
ps I'm a complete moron. sorry about the picture size. only one made it through but I think it will give you the idea.
You must not use your pipe clamps too often. You can clearly see the spider webs bridging the gaps in front of the clamps. ;)
Hi Steve,
Those are the shorter ones. Haven't used them in a couple of weeks. I have several pics but can't seem to attach them. Plus, they're WAY to big. I'll try and get the rest up tonight.
Besides," I don't need no stinking clamps " . Just use my hands and hot hide glue :)
Paul
You need to use a photo editing program to shrink the sizes down. There should be a function called resize or resample or something like that, depending on which program you've got.
Paul,
Let's try this one.
Thanks, Bob. I tried again this morning. Even took new pictures at a smaller size. But even with the resizing issue I still can't seem to figure out exactly how to attach them consistently.
Our resident computer guru ( my son ) recently got married so he's not around as much to help out " old " dad with this stuff. I'll have to get him up here for an in depth tutorial.
Paul
Paul,
Check this out when you get a chance.
If you have any questions Reply to http://forums.taunton.com/fw-knots/messages?msg=36992.1 and I'll help if I can. That way all the info. is in one place and I won't be hijacking this OPs discussio,.
Also, because most of the pics had a size of 0 (zero) it may be an issue with the program you're using to resize them.
I am at the same stage right now. I think I will try something I saw in a magazine a while back using plastic pipes of the right diameter and screwing them together and to a board mounted to the wall.
Brett ,
This is a simple but effective clamp rack.
hope you get some ideas
dusty
Note the spider webs , here in Oregon by the time you put the clamp back the web is there .
angle cut is a good idea.
bbobo,
I have not done this yet..but I'd rather hang my pipe clamps upside down. Currently I use the rafters in my basement to support the clamps. I don't like how the handles are intertwined when I need one...one false move and they all come down. I'm going to look for a small floor flange that would screw onto the end of the pipe clamp. I'll then make spacers to attach to rafters and hang gthe clamps by the floor flange..hope this makes sense..
I made a 4" "shelf" out of 3/4" ply at right angles and fastened it to the wall. I hang all my clamps off it by simply clamping them lightly to the shelf. For pipe clamps, this means only running the tail up to the bottom of the shelf -- no additional tightening of the jaws is needed. For Bessys and quick-release, I just clamp them lightly to the shelf. The virtue of this method is that one rack holds virtually all the various types of clamps I have.
Mike Hennessy
Pittsburgh, PA
Bbobo
Having the clamps on wheels helps when you are doing a complex project as you can take the clamps the to work.
Moksha♠
Man I wish I had the storage space for something like that. I do have a nice wall (about 7' Wide) that I can put them on as long as they are only 8 to 12 inches deep. But I would lover a movable cart. Oh well cant have everything.
Doug
I just nailed two 3" wide boards to the studs across two stud bays. One is almost to the top plate and the second is ~3' lower. I leave the clamps open ~4" and just hang them from the top board. The lower board keeps them from swinging into the bay and falling.
FWIW, only two of my clamps fell during Tuesday night's earthquake.
