Improving on small 14″ bandsaw table
Hi Frank, I have the same bandsaw. Don’t know about the fastrack system but just got the Jet fence and it’s great. Very high quality. You may want to consider it.
Brian
Brian
The plan I've seen and like the best is in American Woodworker, August 2000. It features a 22x22" main table with a removeable 22x22" extension for wide work. The extension has a drop-down adjustable leg affixed with a piano hinge. Fence is designed to go on either side of the blade, and is adjustable for blade drift. LMK if you'd like more info ;-)
Thanks Forestgirl I will check it out.
I have the same saw and after looking at "shop made" I went with the
Rockler table. Has great clamps and the fence adjusts well. It does reduce the cutting height by 3/4" but with a riser block this hasn't been a problem. Also, the circle jig and resaw acccessories work well. I do lots of mortise and tenon on the saw with this settup and love it. Check it out.
Duster
