Switching from power tools to hand tools has this ever happened to anyone else, I am so confused.
Actually if anyone else has one of these jigs laying around and ONLY needs to cut a few dovetails and hates the process of setting up the jig and hates the noise from the router ( I am the guy who claimed to have 17 routers) and dose not have a proper workbench or your electric got shut off you can appreciate this set up.
Great for marking the pins and tails, chopping , and whatever. Try it you will be surprised.
That THING on the horses I originally made to route some mouldings , I need to make a stable base for it. I was Thunkin it could be used for dove tail cutting Races, Put the computitars on oppursitt sides so they can monatur each other during the race . Utt-O to much Roc.
Tom
I know I know I know, PIC 118
On the draws I Laid out the pins and tails WRONG I SHOULD HAVE ENDED WITH HALF A PIN I KNOW AND NEW THIS BEFOR I CUT ALL OF THEM LIKE THIS.
I promise to never do this again it was a bad thing I did And I am sorry.
Tom.
That is an interesting use of the tool. I made something similar, out of wood, just to hold cabinet sides for laying out from the tails onto the pin board.
> a bad thing I did And I am sorry<
It is SO danged easy to do bad things. I am commiserating with you.
roc
