Industrio router table insert issue.
I just got my Industrio router table top with insert yesterday. What I am seeing is the insert is not flush with the rest of the table top. It is about 1/8th below the table top. I did not see any shims etc. can anyone advice on how to fix the issue other than some type of thin shims on the insert to raise to the same level? or is this an issue at all? I would imagine that the insert has to be flush with the rest of the table. I am a newbee to woodworking. Thanks, y’all.
Don't know your insert so can't help on how to get it flush, but DO get it flush. You'll have all sorts of problems (imprecise grooves, stock catching as it hits the table) if your insert is (to woodworking precision) below your table top.
This is the new CMT router table, right? I thought it had leveling screws for the insert. Or is it the ring just around your bit that isn't level??
Good question on the ring because the insert has a leveling screw at each corner.
Since the house is on fire let us warm ourselves. ~Italian Proverb
Thanks, y'all. I found the hardware packet. It had all the leveling screws. I am good to go. As always, thanks for the help.
Whew!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
