Has anyone used the “Woodrat” router system? I recently sent for some info and they sent me a video that shows it to be a rather simple way to make everything from dovetails to mortice and tennon joints. I am trying to decide whether it is worth the rather large expense.
Tim - I bought one about 3 months ago and it works as advertised. If you were going to get a dovetail jig (like the Leigh) the cost winds up about the same but with more flexibility. You can use any dovetail bit, not just the 7 (or 8?) degree that the leigh uses. They sell a 9 degree for small drawers and a VERY large dovetail bit, maybe 2 inches deep, but you could use any off the shelf bit. The mortises also come out perfect though I have only done a few of them. Anyway, very ingenius invention,when you see how it adjusts you will think the inventor is a genius. Hope this helps.
John
Based on your comments I visited their web site and sent for the brochure and CD. The indexing system for dovetails looks quiote simple but I am unclear what happens if you want more than 4 pins or tails. Maybe the brief look I had was inadequate to fully explain the process. Are there limits to board width for dovetails? If you had it to do over, would you.
Thanks - Doug
Doug - The dovetails are spaced by putting the other half of the joint in the clamp next to the router. You put a reference mark on the aluminum top and then can space at any distance you want. They have a paralalagram (sp?) so you can mark even spacings or us a ruler to put at different spacings. Then you use the crank on the top to move each mark on the board to the refenence mark and cut a new socket. When they are all cut you swap boards and use the actual sockets to line up and cut the tails. I may not explain it very well but when you see it a light bulb goes on and there's the "A-ha" moment. I have cut boards up to about 10" but they say you can work boards up to 30" with a jig. You can see a better explanantion at woodshopdemos.com, and yes I would buy it again.
John
Just to add a detail to jmc's explanation: By the method he describes--using a completed tail board as a template for cutting pins--the Woodrat is limited to stock widths of about 12". That's because both pieces have to be in the jig at the same time. But using a paper pattern to indicate where you want the components of the joint to be, you can use stock up to about 30" wide.
All
Thanks for your info.
Doug
Here is a link to an in-depth review
http://www.woodshopdemos.com/wr-1.htm
T
Rev Ted,
Thanks so much for the post. His step-by-step is real service to woodworkers.
Doug
D--
You are indeed welcome. His site has some great info on a lot of other tools also. I noticed the link at the bottom only goes to the index; if you go to http://www.woodshopdemos.com/ you can get the overall idea. I like the methodical approach he takes and detailed pics.
T
