I wanted to check on this though I think it should be ok. I want to do a 2″ x 2″ 1/8 inch think inlay on the top face frame of a bookcase. The frame piece is 3 inches wide 3/4″ thick cherry. I didn’t think a 3″ wide piece would move much so that the inlay lift above the surface. Am I right here? Thanks for your help.
Run the grain of the inlay in the same direction as the frame rail and it should be fine.
Running the grain in the correct direction will improve the look of your inlay work. You will be gluing the inlay in place which will immobilize any wood movement. I have done a lot of inlay work and have not had any problem with wood movement or the inlay protruding above the surface of the main piece. Glue the pieces well and level it properly.
When planning inlay, consider wood movement, moisture content, sealing, and gluing techniques. Allow for natural expansion and contraction, ensure stable moisture content, apply a finish, use flexible adhesive, and consider the climate. Test designs on a small scale or create prototypes to observe material behavior before finalizing the design.
