I’m in the market for a new planer; probably a 15″ model. I’ve heard a few people mention the insert helical cutterheads for planer. Mostly I’ve seen them offered on the bigger, industrial tools but noticed in Woodworker’s Supply that they offer a 20″ with a sprial cutterhead – which I believe is a different beast – and a replacement insert helical for their 15″ planer and for the Jet.
Does anyone out there have any personal experience with these cutterheads or know of someone who does? Any comments, regarding this topic, not politics or the war ;), would be appreciated.
Joe
I'd be interested in any info on this as well. I have the jet 15" planer and it has been a very good machine but this looks like it could be a worthwhile upgrade.
Most people I know with one say they would never go back; I'm looking into retrofitting a General planer, and the next planer I get will definitely have one. Surface quality from a well tuned and sharp traditional head may be a little better, and if there won't be any sanding done to the wood after the planer, that may be a consideration, but if exposed surfaces are going to be sanded, I think it's the way to go. All systems are not equal though, you should look hard at the particular system you have in mind to see if it will give you the quality you want. I'm not knowledgeable enough to give you a rundown on what's out there. If you check the forums at woodweb.com there is a fair amount on this in the archives.
cabinetmaker/college woodworking instructor. Cape Breton, N.S
Thanks for the reply. I haven't been but will go to woodweb and see what is said there. My old college woodworking instructor showed me the head on their new planer and said it was great in school situation; easier to adjust, held up to abuse and with the ability to elimanate nicks by rotating those particular blades.
'....but if exposed surfaces are going to be sanded..." Who doesn't sand?
Thanks for help.
Joe
Thanks for the post. Hope there are a lot of experienced replies. I too am thinking about an upgrade, but on my old 12" jointer. I was quoted about 1200 by Byrd Tool, out of Kentucky. http://www.byrdtool.com/journals.html is the web address. This did not seem too unreasonable since it will have to be made specially to match my existing set-up. I haven't pulled the trigger yet, but my finger is a bit itchy. There was a fellow who posted here some time ago that he has a general jointer with such a head, and he says it is great. He doesn't even have to look at grain direction anymore, I think he said.
Alan
Hi to all:
I bought a Bridgewood 12" jointer with spiral head about 6 mos. ago and I love it. It has proved to me to be true that you don't have to be concerned about grain direction anymore. Also a BIG plus is that when you have to install new knives almost any idiot can do a perfect job in no time.
Does your machine have the thin, flexible balde that lays across the cutterhead at an angle or is it the one with multiple small blades attached to the cutterhead? I've seen machines offering both and wonder about the difference in performance as well as replacement.
Thanks for the info.
Joe
Hellow to ArcDesign:
My cutterhead has the small square inserts that spiral around the cutterhead. They are 4 sided so you can rotate them 4 times, then replace with new ones at a cost on my jointer of about 100$. Also, they only can be put on one way so there is no adjusting whatever. The only downside to this type of cutterhead that I know of is that you can only take off about 1/8" at a pass, or less. For me that is ok because of the work I do I do not need to hog off lots of material at each pass.
I'm not familiar with the other type you describe, but am very happy with the performance of mine so far. thanks for the email, Rubb.
