Is there such an animal as a cup hinge that will work on a cabinet door that is inset 3/8″ with a face frame??
customers want new hardware and i didn’t this specific app. covered in my Lee valley catalog
Thanx in advance…
Mr. T.
The Emperor has NO clothes!!!
the emporer has no closet…
the emporer has no clue…
the emporer needs someone to tie his shoes..
the emporer doesn’t care about polls (they can be fixed)
If you mean that the face of the door will be back into the cabinet 3/8 from the face of the face-frame, I don't think you will find that.
I think you might be able to get there by building out on the back side of the ff to have a place to mount the hinge plates unless you want to build out the ff by that amount.
I'm not completely sure I understand what you need. But if you are talking about inset doors, yes of course there are Euro cup hinges for that. If you inset them 3/8" from the faceframes, you will probably have an opening angle of about 100° or so before the opened door hits the frames. If you really meant a 3/8" inset on rabetted doors, it also can be done, but this is a specialized set-up. Blum and friends do not advertise the possibility but I've posted in the past on how to solve it.
DR
check this old post to see it - 9868.16
Edited 5/21/2006 1:17 am ET by ring
Here's a page out the Blum catalog showing how to do a 3/8" rabbeted door and a 170-degree cup hinge.
http://wwhardware.com/media/products/apcharts/blum170special.pdf
After I thought about it a while, I realized it was pretty much impossible to do 3/8 rabbeted doors with cup hinges on face frames...
probably would work with blocks tho...
I'm just gonna tell them it would be more work and more $$.
They were not set on cup hinges anyhoo..
Tx
Mr. T.
the emporer has no closet...
the emporer has no clue...
the emporer doesn't care about polls (they can be fixed)
