What is the easiest or best way to install flush mounted brass ring pulls onto an existing set of drawers? Can I cut a recess into the existing drawer faces, and if so, with what tool? Do I need to make new drawer faces with recesses that will accept the flush mounted pulls?
thanks,
d
A router using a template and guide is the best tool for the job. Depending on the shape of the pulls, the corners or other features or the shape may require finishing with a chisel.
Good luck
