As my first woodworking project, I’m finishing our laundry. Above the washer & dryer I plan to install two rows of 4 16″ H, 16 W and 20″ D to keep rectangular baskets for sorting folded clothes. I will use 3/4″ plywood cases and backs (rabbets and screws), attached to the wall studs.
My concern is the depth of the cases and the weight involved in that dimension.
I will appreciate any advice towards making this part of the project safer.
Thanks.
Pinenut
I'm not sure I understand the overall dimensions. The reason I ask is that studs are normally 16" from the center of one to the center of another. 24" on some outside walls. They are only 1 1/2" thick. A box that is 16" overall, with 3/4" sides will only allow one stud to be hit. I would want to hit two, at least. It would be a good idea to locate the studs and adjust the size of the shelf width, so you will connect well. With a 3/4" back, integrated with the shelves, you shouldn't have problems with attaching through the back. Obviously, you want to hit the studs, top and bottom and use proper mounting screws, not sheetrock screws. It may help to remind folks it isn't intended to store heavy items. You could always put decorative support brackets underneath and spiff up a plain Jane.
Thank you for your reply, Hammer 1--
When I read your message, I went right away to check the studs. They are 16" on center and will fall within the cases, so I will be able to screw the back to the studs. Except that, I think, I will need to have one back for all the 4 cases in a row, instead of one back for each case; that way, each row of cases will share a stronger back. I was considering even using a French cleat plus the screws.
Thanks again.
Pinenut
If you use a single back, why not make the whole thing a single box, using 1/4 ply for the internal dividers? You'd save a bit of weight. You could even make a few extra dadoes on the bottom and top and insert additional dividers if you decide smaller or bigger spaces are needed. Maybe just permanently fasten a divider in the middle.
