Installing Built In Bookcases Question
Total length that I am installing is 15 feet, but baseboard molding is longer. Would you take off the entire length, or I was thinking of using my dremel oscillating saw to cut wear it would end. Appreciate to hear what you think. Thanks
Unless you're single, I would remove the whole baseboard, install the bookshelves, then use what you took off to fill in where it's needed. If you have a partner, then at least get, in writing, that where you're cutting out the spot for the bookshelf is exactly where they will want it, and for all eternity.
100%
Pull the whole strip. It's great that you have a plan, but plans rarely line up to a mitered 1/16" caulk joint at the end of a renovation.
