Ladies and Gentlemen………I need your help and expertise!!
I have built my first set of kitchen cabinets and I’m currently at the stage of installing drawers. I have in fact built a few of them and have installed them to discover that the face of the drawers in some cases is not exactly flush (parallel) to the face frame. For instance the face front on one side may be indented by 1/8” while the opposite side extends beyond the face frame by the same….. while the drawer is square.
Now these fronts are designed such that I will build a false front of 3/4 cherry that will be screwed to the true drawer face just described. These false fronts must when closed must meet the face frame exactly. Would I be thinking correctly when assuming I must now shim the drawer slides appropriately to make this false face front parallel to the face frame when closed? And if by chance I’m on the right trail with this thinking, what would you recommend I use to shim these slides?
Many thanks……….JimJp
Jim,
What type of drawer slide are you using? Most allow for some side to side movement at the rear of the drawer to allow for what you are describing.
Lee
I'm actually using two different types. One is the new Blum self-closing , side mount slides. The one I installed was nearly .....perfect? The other two I have installed are the basic inexpensive slide that has been used for years.I'm sorry for the lack of any better description, but they are up at my cottage and I do not know the manufacturer?Jim
reset the drawer glides...move one up or back...until they're flush. Common problem...easy fix... or maybe your case sides are a touch out of square. In that case you may have to shim out the slides with washers or shims...
Edited 4/19/2007 9:07 pm ET by Jimmy
thanks for the note..........life is so easy when you don't see everything as a problem???
What yer describing is to my perspective, unsquare drawer boxes.
Better that than unsquare carcases.....
No doubt this will send you reaching for yer framing square to ascertain the squareness of the boxes, but before you do, check that yer framing square is indeed square. lotsa unsquare squares out there.
heavan forbid that you used an unsquare square as a reference point all along, cause if you got unsquare carcases and unsquare drawer boxes, you got a real problem.
Opting for the simplest solution.....
I'd say the flexibiltiy in your drawer box construction will determine the solution to yer problem. If the bottom is 1/4" thick and is only captured in grooves on front and sides, nailed to the back, yer drawer box likely has enuf inherent slop to correct this-but you may have to pull the nails that attach the bottom to the back of the drawer and square up yer boxes.
OTOH, if yer drawer box has a solid 1/2" bottom glued and fastened on all sides, if it is out of square, it's gonna stay out of square (but still be rock solid)-there shims will likely be yer only solution shoirt of rebuilding drawer boxes.
I dunno what kinda drawer boxes yu got-cannot see them from here.
Hope that helped ya.
Eric
Thanks, every little bit helps. Yep its glued for good......shim is going to be the way out.......I Hope???thanks........Jim
