I’m going to build some interior window shutters (raised panel) and would like to raise both sides for esthetics. Suggestions on bit(s) and technique appreciated.
Joe
Joe
I can't tell whether you want a shutter or a raised panel? Two different things.
These I made on the TS, but I would like to make the rest on the router table.
Joe
ok, so these are raised panels. I'd use a vertical raised panel bit. This newer style replaces the older horizontal, and a little more dangerous, style.
The spinning mass of the bit stands vertical so there's less vibration and noise. They work well- you'll just need a good router and table with a tall fence (you can make).Fence should be at least 4" high, taller is better, cut endgrain first then edgegrain. I've done this in oak with a 1.5 hp router, several passes; a bigger hp motor would help.
vertical raised panel bit as stated in the other post is the way to go..
For what it is worth.. Make a TALL fence and some feather boards..
I would also suggest that the table on the out-feed be as long as possible AND FLAT..
Well some support out there that will not cause your stock to move..
I have one that replaced a Horizontal.. Horizontal scared the blank out of me...
EDIT..
I forgot.. I did the cuts in several passes.. But then again I do that with all my work on the router table. A little extra work but better results.. I think?
Edited 5/4/2005 9:12 pm ET by Will George
When raising panels with a vertical bit,use a horizontal router table. Let gravity work with you, not against you. If you are raising them on table saw, see Ian Kirby's article in American Woodworker(Dec 1998-#70). He builds a carriage that tilts and the blade remains vertical. Wowed a lot of folks the last time I taught a table saw workshop with this jig. If you can't find this issue, let me know and I will lend you a copy. You can also use a moulding head on a radial saw(Yes I said radial saw!). If they are cove cut you can also use a moulding head on the table saw. Use 1" round cutter for best results.
Joe ,
Another option is to make separate panels and place them back to back in the frames if you have enough thickness in your frames .
good luck dusty
I sliced the panels front and back on the TS (flat profile) for the first couple and dropped them into grooves in the rails & stiles. My shaper bit (ogee) cuts too deep to raise front & back on 3/4" stock. That's why I used the TS method to let me cut a profile on both sides. Left about 3/16" to fit in the grooves, as I remember. I could do the rest the same way of course, but I like the ogee shadow line and I like the idea of vertical cutting as it looks safer.
What I was hoping to hear was, " get bit xxxx-xx from XYZ router-bit dot com and you don't have to think about it antmore!". What me lazy?
Thanks all,
Joe
CMT makes a 'junior' sized kit for thinner frames and panels. I think 7/16 is the recommended minimum thickness. Since you want to do both sides on thicker panels this may be your "XYZ" answer.
Greg
I'll look it up..........Thanks guys
Joe
