My name is nick and I live in NW Pa. I work at an organ supply shop, in the wood mill, when i’m not at school. I also use my dad’s shop, being as i’m 18, I don’t have one of my own. I just recieved a new stanley #4 bench plane, and I’m going to tune it via the David Charlesworth method. Which would be a good blade/ chipbreaker for me to buy? Any help would be appreciated, thank you.
Nick,
You can't go wrong with the Lie-Nielsen blade and improved chipbreaker, or those from Hock; they're both excellent. I prefer the improved chipbreaker to the standard chipbreaker because it fits the blade to tightly and precisely, and doesn't squirm out of position as you tighten the screw.
Good luck,
-Jazzdogg-
I think I will go w/ the lie-nielsen, thanks
Nick... just be sure to tell whoever you're buying from that the blade is intended to upgrade a Stanley plane; there's a limit to the thickness of steel that the Stanley adjuster can cope with.Mike Wallace
Stay safe....Have fun
"organ supply shop"
that conjures up all kinds of images! :)
lol,
http://www.organsupply.com/
Hi Nick. I own 2 brands of aftermarket replacement blades Lee Valley and Lie-Nielsen. The LN is quite a bit better. I would definately get the improved chip breaker as well and as someone has already said you must specify that this is going in a new Stanley because yes there is a limit to what will work. Using the Charlesworth methods is definately the way to go but be patient. I also use the ruler trick and I wouldn't even think of sharpening any other way now. I purchased Norton waterstones in favor of my Kings. Have fun. Peter
