I have an exhaust fan in my shop. It has a hysteresis motor, so it has no brushes or commutator and as such makes no spark. Would this be an acceptable solution to exhaust overspray from spraying shellac?
Quick,
The hysteresis motor, being an induction motor is a type of motor referred to as "explosion proof." The motor itself, having no electrical sparking potential is "safe," but if it has any mechanical switches included for a starting capacitor circuit, these can be an explosion source and should be in enclosed "pots" that are sealed with gaskets.
Of course, any of the switches which turn on power to the motor must be out of the area where the spraying is to occur.
Rich
True explosion proof motors are designed to harmlessly contain the explosion of any vapors that get inside of the motor housing, anything less isn't considered explosion proof and a true explosion proof motor will be clearly labeled as such.
I don't know what a hysteresis motor is, the term isn't commonly used, but if it has a starter circuit with a centrifugal switch, or a thermal switch to prevent overheating, both will generate a spark.
A hysterisis motor doesn't have a starting circuit so it is fine. More importantly, if the vapor concentration passing the motor ever reached the lower explosive limit (LEL), then you would likely be passed out in the corner, or dead. The areas where you would need to be concerned would be dead-air, not flowing air.
Good point John.
True explosion proof systems are very complex. They allow gasses to ignite then expel in some controlled fasion.Pardon my spelling,
yeah, as a rule if it doesn't say "explosion proof", it isn't. explosion proof is essentially explosion containing. intrinsically safe equipment is designed not to produce a spark or heat source with enough energy to act as a source of ignition. oh, and you would reach the LEL of most VOCs well before oxygen deficiency would be a problem. acute toxicity varies.
Amateurs talk strategy, Generals talk logistics.
I haven't a clue as to whether a hystersis motor is explosion proof or not. What will happen over time is that the open motor will eventually fill with the over spay being drawn through and that may cause overheating. If nothing else the motor's life will be shortened and need to be replaced in the future, and the hunt for a suitable motor will be resumed. The other question that should be considered is, what would the insurance company do if it was found that a motor, not rated for this application, was being used and a fire resulted?
I've only seen hysteris motors in use in one place I worked... and it was one of those 'if I told you I would have to kill you' scenarios. But yes, from what I recall of them they should be as explosion proof (in terms of not causing/propagating a spark or ignition source) as anything you can find. As others have touched on already, whether the overall construction of the motor, it's housing, etc. meets the legal definition of 'explosion proof' is a separate issue.
