A friend of mine read recently that Simple Green should not be used for cleaning saw blades because it can damage the carbide.
I have been using Simple Green for years to clean my saw blades and router bits. It’s not as fast as lye or oven cleaner but its not corrosive and its non-toxic. but always seemed to do a good job.
Does anyone have any more information about this?
Dennis
I once cleaned an entire MG with the stuff
Not the engine internals. I can't be around Simple Green now ; messes with my lungs.
Citrus cleaner is better and doesn't mess up my lungs. Been using it for more than ten years now.
http://www.amazon.com/Zep-Commercial-Citrus-Cleaner-Degreaser/dp/B0063L048I/ref=sr_1_8?ie=UTF8&qid=1326447997&sr=8-8
That's a rip off from Amazon. I just showed that one because it was easy to find. Local Home Depot is way cheeper. (no shipping)
Works on regular blades with pitch on them like from purple heart wood.
Look at your carbides with magnification. Are they pitted or discolored ? Is the silver that holds them on attacked ? Sounds like if you have not had problems by now then you won't.
Wear a full face shield around carbides ; even when factory new they can fracture and kill you.
http://www.amazon.com/MSA-Safety-Works-817893-Adjustable/dp/B00009363F/ref=sr_1_4?ie=UTF8&qid=1326448489&sr=8-4
Freud did some tests and found that it is not good for blades. Below is a link with pictures. I use CMT blade cleaner and find that it works very well quickly.
http://www.sawmillcreek.org/showthread.php?81102-Carbide-and-Lye-(Oven-Cleaner)-Problems&p=821475#post821475
soak or not?
Do you soak your blades or bits for a determinate time or just spray and brush?
I spray on the blade and let it work for no more than 5 minutes.
http://www.amazon.com/CMT-Formula-2050-Blade-Cleaner/product-reviews/B0006G83W0/ref=cm_cr_dp_all_helpful?ie=UTF8&showViewpoints=1&sortBy=bySubmissionDateDescending
The manufacturer of Simple Green specifically recommends NOT using their standard product on carbide tooling. They have product intended for cleaning metal which they say will work fine.
I haved tried Extreme Simple Green. I like the CMT blade cleaner better, it is fast and effective.
New twist !
That is a new twist on Simple Green, thanks.
A soaking in lacquer thinner works if you enjoy a Buzz. But I set it outside to soak in a pizza pan.
Simple green
I have been using 409 for many years and it works well. About a 1 or 2 minute soak in a shallow container and the soap and crud can be wiped off with a paper towel. It will corrode the steel body however if left for long periods as in overnight.
