Hello, I’m making a walnut hall table and it calls for dovetail cuts, that’s not a problem, I’m wondering if what they show in the photo will cause kickback. Is this safe or should I flip the board and rout it?
Thanks.
Thanks.
It is safe but personally I prefer cutting against the rotation of the cutter head. I wonder why they do not place the dovetail bit partly in the fence and do away with the jig .
Thank you, I wondered that myself. I'm going to be cutting on scrap as always but I have always thought this is the incorrect side of the bit to be cutting on.
Cutting with the work trapped between fence and cutter isn't as safe as feeding in the conventional direction but the climb cut will generally create a cleaner cut. With the sled behind the work there's not too much risk of any problem.
This is the sort of thing I prefer using the Router Boss for instead of my router table.
Thank you Dave. Never heard of the Router Boss though.
It's not generally safe to rout a workpiece between the bit and fence. You'd have to pull the workpiece toward you to avoid a climb cut
It's much better to just partially bury the dovetail bit in the workpiece, as you hold it against the fence.
Thank you sir, this is what I'm going to do.
I’d take scrap and try both: as shown and with bit buried in the fence. I’d personally use the bit buried in the fence and make a shallow pass first.
Thanks. I'm going to make a tall fence out of MDF and bury it.
Do it with the bit buried in the fence. No reason not to.
Many thanks!
If you rout between the bit & the fence, the bit will cause the board to shoot out the left side. More trouble than it's worth.
Thanks, that's what I was afraid of and it just didn't look right.
Using the router set-up and pushblock as shown in the photo would work fine IF you move the workpiece from left to right. I think the photo shows the workpiece movin R to L, which would be dangerous.
