It sucks, but not where I want it to
I have a cement floor in my basement, and my table saw is sort-of centered in the workshop. How the heck to I get ducting or flexible tubing from the dust collector to the saw? Right now it’s just run along the floor, but this makes me nervous every time I have to carry something from one end of the shop the other. If I run ducting overhead, I’ll have to drop it somewhere to get to the bottom of the saw — and if I do that close to the saw itself, it will interfere with cutting operations. I now massively appreciate the convenience of a raised floor, but that’s just not an option due to a limited overhead. My other WW machines are closer to the walls, so overhead ducting to them is quite feasible — it’s just my TS I don’t know how to approach.
Any suggestions? How have others solved this?
-M.
Hi Mark,
We have this at work with one of our saws, ducting runs away from the bottom of the saw at an angle of approx 30 degrees to horizontal, but the initial ducting is flexible tube, so we can (with an assistant) bend the tube out of the way and around the timber on the odd occasion that it interferes with the cut (location is approx 1m off the centreline of the blade at the level of the table). As well, the dust collection off the saw guard is also patched into the same line, with a small length of flexible tube (again).
Alternatively, you could run the duct along the floor and put a ramp over both sides, still not ideal but at least safer.
Just a couple of ideas. I'm sure that others will come up with something safer and/or easier.
Cheers,
eddie
Edited 3/24/2003 4:28:37 AM ET by eddie (aust)
Edited 3/24/2003 4:29:04 AM ET by eddie (aust)
Mark, Put your duct down from the ceiling to the back corner of the saw, on the opposit corner from the side of the blade the the fence is on. If you are going to be cutting down the middle of a 4' X 8' sheet a lot, then take the duct off center 30" Think about it.
Good Luck -The Bohiemian
The current issue of Wood Magazine has a section dedicated to installing a dust collection system.
Roger
Hi,
To avoid this problem I put my dust collector next to my saw. I use flex hose to connect and it lays on the floor. It is also the shortest run in my shop. I am in a two car garage and have support poles running down the middle making the middle space not that usable. I grouped my router table, bandsaw and jointer to the left behind the saw. This allowed a short ceiling run to this equipment. I have a infeed/work table behind the saw to the right. All other equipment is around the edge of the room, and my SCMS is on a rolling cart with wings so I can move it outside.
Oriole
MarkH-
I have absolutely nothing to tell you about dust collection, but just wanted to say that the title of your post has become my new saying. :)
Kevin
"It sucks, but not where I want it to."
One of the shop layouts I've seen had the DC located in the middle, with 3 machines arranged around it in a triangular arrangements. Group included tablesaw, can't remember for sure the other two.
forestgirl -- the one who got "sucks" taken off the censored list!!! ;-)
Thanks FG, Talking wood without "sucks"? Your my hero...opps, heroine.
PS..Is there really a "seven words you can't say" list?
Brian
At least seven, I suspect!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
That reminds me of George Carlin's old bit "The seven words you can't say on television". Saw him live once, what a great show.
I had a second thought which leads to a question. Where's your power cord? Isn't that in the way too.
Enjoy, Roy
That old Carlin routine was hilarious.
Yes, I have the same problem with my power cord -- it's strung along the floor.
Once I know how to solve the ducting problem, I'll re-route the power to follow the same path. Right now, I'm a major fan of the approach that Tom F. and Terry H. have implemented on their saws -- dropping the duct at the upper right corner of the table.
-M.
The island idea is a good one for larger sized shops but you may run into future problems wanting to add other machines later. Wrap everything around the walls. Try setting your tablesaw like a penincula to the left or right of a workbench, or a machine or two in between. I have my table saw sitting to the left of a workbench and scrap bin, access from the front, leftside and rear but not the right. DC comes in from under the workbench top, nice short run, well not really, but no verticals.
But, I did start the "Most Trashed Shop" thread! :o)
Enjoy, Roy
Buy a small DC unit and stick it under the extension table or do as I do and use a shop vac for the table saw and hook up everything else to a big DC.
The proof is in the puddin'
I've found that the jointer is the easiest machine to collect from when it comes to using a vacuum. Must be because of the low percentage of dust compared to shavings being produced. Vacuum is somewhat useful with the tablesaw, but nothing compared to a DC.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
How about a dedicated shop vac to the table saw by itself?
In my old shop I had the duct drop from overhead at a point just to the right of the farthest reaches of the fence. This arrangement was seldom, if ever, in my way.
Mark,
Here's how I did it:
TDF
Yes, I see. Excellent idea.
-M.
I placed PVC runs and conduit before the floor was poured, but that isn't much help to you. Any chance you'd consider cutting the cement? Noisy, messy and probably expensive unless you do it yourself with rental gear but if you're sure you're going to stay in your current home/shop it might be worthwhile. If considering cutting the floor make sure there's no existing drain lines crossing your intended path.
http://www.wood-workers.com/users/mach70/smdcsaw.jpg
Gotta go w/ a dedicated vac..Emo tells me Fein makes a mdl that is actuated when the saw is turned on. Sounds perfect. Brian.
PS...Great title! :)
Mark,
Placing the vertical run at the RH rear corner of the saw won't interfere with the use of the saw at all. Here is what I did.
Terry
More dust collection ideas here:http://www.dusteliminator.com/shoptour.html
If you are interested.
Edited 3/25/2003 9:35:38 AM ET by Terry H
Edited 3/25/2003 9:36:28 AM ET by Terry H
I can't answer your question, but I have to say this is the cleverest caption I've seen for a long time. I bet every (male) woodworker opened it.
