I’m having trouble with my ryobi 12″ planer.It is having difficulty feeding the stock through the rollers.I have to pull or push the stock to get it thru .I checked the manual to no avail.Any ideas?
First and foremost are your blades sharp and have you cleaned the feed roller?
The machine is relatively new and used sparingly , when you say clean the rollers doyou mean of woodchips and is there something they should be wiped down with?
Sometimes you need to clean the bed, and lubricate it. The drag against a contaminated surface can cause this. I like to use a paste wax.
Thanks I'll go over the bed and rollers ,the last thing I ran was about 10or so 2 foot 2x4s could they have contributed to the problem because before that It was working fine?
They probably left a little pitch on the bed. Don't get the wax on your feed rollers.
If there is pitch on the bed you should be able to see it. Best bet, clean the bed first with mineral spirits, then wax it. Don't wax it without first cleaning it. You don't want a mix of pitch and wax.
Seems like 99% of the time when this problem comes up it's due to dirty feed rollers. A mild household cleaner should work, I've even used Kirkland or Mr. Clean "household surface wipes". Be sure to wipe off the cleaner afterward.
