Any idea where I can order jappanning supplies?
Alan – planesaw
Alan – planesaw
Alan:
If you haven't already, check out Todd Hughes & Sean Cullen's excellent article on japaning tools over at Woodcentral: http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=handtools&file=articles_117.shtml
Besides the BLO and turpentine, the author's identify asphaltum as the key ingredient in japanning, and it's supposedly available at larger art supply stores because its more common usage is in etching and lithography. I think the article mentioned an online source as well.
Marc
I make my own using this recipe. http://www.paranoia-towers.com/alchemy/pontypool.htm
Now, how you acquire all the modern day equivalents to the ingredients is a trade secret! :)
PlaneWood
Mike, I was hoping you would chime in. I figured you would know something about this. Any idea where I can find something already mixed / concocted? I want to redo 4 or 5 planes.
Alan - planesaw
No advice to give, but got a question. What is Japanning? In the whole week I've been a cabinetmaker I haven't heard of it. From the little I've read about Japanese tools I'm inclined to think it's a hardening technique, but like I said, it's only been a week (or so).
It's paint.
Thanks. But gee I feel foolish.
No reason to. That was my reaction the first time I heard the term.
Some say the technique originated in Japan. Japanning is the common term used to refer to the painting of, for instance, Stanley planes. Lots of iron work was finished this way in the 19th century. Japanning, as applied to Stanley planes, produces a glass hard high gloss black finish. Asphalt and linseed oil are the primary ingredients.
One of the guys here at work was just asking me this morning about japaning for some 1930s era Stanley tools he's refinishing.
Sherwin Williams sells Asphaltum paint thru their commercial coatings outlets. I believe that will do the trick nicely. I've never used it, though. All I have is their Spec Sheet on it. It's thinned with Mineral Spirits to varying degrees depending on if it is going to be sprayed, dipped, or wiped on. The sheen is listed as Semi-Gloss to Gloss.
Kevin
The Independent Voter.com
"Rather fail with honor than succeed by fraud" - Sophocles.
The best products are available through several suppliers in Japan.
Is that like ordering French Fries from France?
Alan - planesaw
Most definitely.
