Hi:
Made a mistake last week and bought quite a bit of Jatoba. Thought I was picking up bundles of cherry that I have purchased at this place before. I got 36 pieces of of 2″ by 2″ and 2 feet long. I was thinking of using the cherry to make the tail vise on my new bench. This wood is a dark red color, very heavy and I think they call it cross grained. When I try planing it by hand it comes very smooth but the shavings don’t come off in 1 wide slice as cherry would.
Does anyone know anything about how I could use this wood. Was thinking of making some small tables (If I ever finish this @#@5 bench). Would this wood be appropriate. I only paid $1/piece. My shop is full of bargains I bought and never used.
Roger
Rog, at a buck-a-pop, you got a real steal on that jatoba. That works out to only $1.50 per board foot...So, quit moaning and get on with it. :O)
Actually, the jatoba would be a better species than cherry for bench jaws. It's much harder and stronger than cherry. It's also a very nice cabinetwood, both in terms of appearance and also strength properies. You'll have to put some real sweat equity into the project, if the design involves a lot of hand tool detail, but otherwise its working characteristics are very good. It's moderately stable (lower than average T/R ratio and about the same volumetric shrinkage as black walnut.) Also, it has outstanding decay resistance, if you want to consider using it in an exterior application.
You want to sell any of it? I could use about 9 pieces. That'd make a nice square bundle. I get lots of orders for Jatoba handles and knobs.
Or, if you need some plane handles take it in trade??
PlaneWood
You got some of the low down on Jatoba. It is a very nice wood with some wonderful color and grain. It works pretty well, although it will splinter along edges if you're not careful, and finished nicely. This is one of a pair of tables made with Jatoba. The finish is BLO/MS mixed 1:1, blonde shellac and waterlox satin.
Thanks for the picture. Nice table! I would have to do a lot of laminating to get my 2 by 2's into that top.
Roger
Hi
Could you please provide more info about the finish. I am a beginner and can only guess what that means. Nice looking finish. That is where I always screw up. I use stuff out of a can and don't really know what I am doing. If you could briefly detail the process for me it would be of great assistance.
Roger
I am by no means a finishing expert and sought a lot of advice in the process. The initial 2 coats were Boiled Linseed Oil thinned 50%/50% with Mineral Spirits. The BLO highlights the grain and figure. I put two coats on, the second was wet sanded with 320 grist wet/dry paper. Wet sanding helped fill the grain a bit. The blonde shellac both sealed the oil coat and appeared to lighten the color a little bit - it was applied mostly as a sealer coat, though. It was brush applied, then sanded. Final coats were Waterlox Satin, applied with a foam brush, sanded between coats. The Waterlox was very easy to use, self-leveled quite well. It was sanded between coats with synthetic steel wool (0000 equivalent).
Hope that answers your questions!
Colinsdad:
Thanks for the info. I will print this off and keep it in my shop for when I make one of these tables. I just finished putting the first coat of tung oil on the base of my bench. A few more coats and then I will be ready to start leveling the top.
Roger
I guess that's a NO on selling any of it? (I have to go buy some today - just ran out)
