About two years ago I bought the after market spring/nut and handle for the blade tension adjustment from Highland Hardware.
Noticed the last couple of times I adjusted tension it was more and more difficult to achive proper tension. Disassebled everything an it seems that the threads on the adjustment shaft are streching/breaking.
Thought about replacing with “Spinner 3 Bandsawtesioning Crank” http://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=5620
Has anyone tried these?
Also what is the over all opinion of replacing my cool blocks with “Band Rollers” for resawing? Using cool blocks for 1/4″ and smaller blades?
To announce that there must be no criticism of the president, or that we are to stand by the president, right or wrong, is not only unpatriotic and servile, but is morally treasonable to the American public. Teddy Roosevelt 1918
Scarecrow,
It would seem to me that if the threads are breaking up and stretching, a crank isn't going to help--the threaded rod is failing--about to break. Either you are seriously over-tensioning your saw (unnecessary), or you got a bad one. Not hard to do. If you really need to crank it down that tight, go to Enco and look for grade 8 threaded rod. That'll hold until the blade or saw frame breaks--neither is desirable.
Make saw dust, not war.
Steve
There are two secrets to keeping one's wife happy.
1. Let her think she's having her own way.
2. Let her have her own way. President Lyndon Baines Johnson
I wouldn't choose a grade 8 unless what it threads into is easily replaceable. Any threaded connection that gets regular use will wear, so you want the cheaper part to be softer. It's a lot cheaper to replace a threaded rod than a casting, for example.If you do go with grade 8, you'll need a carbide blade to cut it.Pete
Edited 9/16/2007 11:33 am ET by PeteBradley
"It's a lot cheaper to replace a threaded rod than a casting, for example."
On my saw, the rod threads into a captive nut, so that wouldn't be an issue. Other saws may work differently.
The "Crank" is a new rod and bronze nut assembly. I do think my adjustment rod is too soft. I'm using a highland hardware woodslicer 1/2 resaw blade and I'm barely able to tension it to 3/8's now.
The after market spring is the Iturra spring.
I've pretty much figure to replace the adjustment shaft, but not decided if I want to use the same or maybe better quality one.
http://www.drawingwithlight.smugmug.com
