Hi all
Bought the Jet 18 in bandsaw.
Great deal.
Great condition.
Cuts well.
Someone mentioned that the guides (European Style Bearing) could be
changed to another.
I have no manual or other info on saw.
Could someone fill me in on options and anything helppful on this
unit.
Jeff:
You can view (and print ) manual for jet band saw on their site http://www.jettools .com
http://www.jettools.com/JETGeneral/Manuals/Woodworking/Manuals/JWBS-18B.pdf
Good luck
Ben
Thank you for the info.
Unfortunitly, my computer software isn't compatable with the Jet site.
I have been unable to get past the 1st page.
Jeff,
If your puter will allow...Woodcraft sells the Jet 18" with the Euro guides..and also features the Carter roller bearing guides as an upgrade. As I remember the Carter guides and Jet guides look similar at least..
You might think about giving that Commodore 64 a rest....lol
BG
Commodore ! Please !!
It's an Apple IIe
PS Thanks, I'll checkout Woodcraft.
(Problem is I can't update my Netscape 4.5 because that is the only
version that works on an FCC site I use.)
The Jet site requires netscape 6 or higher, and I'll be gosh darned if I'm upgrading from 4.72 which works to 6.0 or Ugh! 7.0 for just one site. Don't even think of bringing up Idiot's Explorer.
So far, I haven't noticed any improvements in 7.0 (which an idiot loaded on a machine at work), but it does ask if I want it to remember passwords when I visit webpages that require them. Oh, now that's secure! I'm just waiting for the hospital to require that netscape 7 be taken off all machines, all 10,000 machines.
I also like the new porn policy. If I click on an attachment at either knots or breaktime, it comes back as "Forbidden pornography." Just what have you guys and gals been etching into your projects? ;-)
Yeah
Drives you nuts sometimes, doesn't it.
hey Jeff..
bought the same saw abot three years ago, and i love the beast.
mine has the euro guides, i have found no need for any up-grades; time will tell
i re-sawed a piece of 20+ year old walnut with a 3/4 re-saw blade; and the only reason it slowed down was i kept poppin my circuit breaker.. the log was about 8" diameter.
i have used the saw mostly to re-saw, and have'nt had smaller than a 1/2" blade on it. i find you have to tension the blade by feel, as opposed to using the guide. my 3/4" blades seem to cut better at 1" indicated on the scale.
i should say that these are not the best blades on the market, but adequate for my uses.
that being said; enjoy!!!!!!!
casey..
Thanks Casey
in the F.W.I.W. catargory i've had the 18" for about a year and upgraded the spring to an aftermarket spring from iturra in jacksonville, florida 888-722-7078. the spring got to me in two days , and really optimized the tension on the blade. the measurements they needed from the spring are length (2.355 inches), width( 1.145 inches), thickness of gauge of spring(.240 inches). one more measurement they needed was the diameter of the rod that goes up the middle of the spring that was if memory serves alittle smaller than a 1/2". it was 16.00 and well worth it. i'm reasonably sure all springs in 18 are the same but i'd double check just for giggles...... slainte bear
Thanks bear, I'll check.
thanx, Bear. damn if i did'nt lunch the lower thrust bearing(no pun) this afternoon!!! ouch!!
guess i am on the phone tomorrow...
casey..
Casey
Let us know what happened and the outcome.
All info is helpful.
Jeff, called Jet today, and did'nt wait for the answer; too much elevator music..
will try again on the morrow..
Bear; thanx for the info, will maybe replace the spring, seein as the saw is down, anyway.
ya'll have fun, and i'll let ya know!!
casey..
Oh yes, music on hold.
I know that problem well.
Good luck.
Jeff,
got through to Jet today, (5/6) and they are sending me a new bearing and shaft. To their credit it took only about 2 min. to getr a rep on the line.
The bearing and shaft w/ shipping will be $10.73. Little Miss Myra was quite pleasant, and I should have my part in a few days, U.P.S. ground.
Damn good thing, cause i gots some work to do!!!
Have fun, bud..
casey..
Casey
That's great.
I'm still waiting for a manual now for 3 weeks.
jeff..
sorry to hear that bud! did you throw money at them? they will quite often respond to cash. i have a phone no. i used; 1-800-274-6848; and got a good response the second time around.
good luck to ya, and keep an eye on them bearings!!!
yeee-haw!!
casey..
Casey
When I asked how they wanted me to pay, the gal said that there was no charge for the manual.
I said "free, no charge" and she said that was there policy, and they
would send them to me shortly.
I would rather pay and get then asap then wait in limbo forever.
If you have a manual, would you Zerox a copy and send me it?
I'd be happy to re-inburse you.
Jeff,
i' be happy to. I'll get on it tomorrow, 5/9.
i think i can scan it o.k. here.
Just e-mail yer adress, and i should be able to mail it out to you on mon. 5/12.
cheers,
casey..
jeff; new message.....
manuel is copied, and if you send me an adress, i can send it on fri5/9 please to pay for snail- mail??
you'll receive my mail adress with the package.
have fun, bud!!
casey..
Edited 5/8/2003 10:50:13 PM ET by casey
Casey
That's great, thank you.
spirerjd@sover.net
jeff,
you are copied, and i will send it out tomorrow, fri. 5/9.
have fun, son!!!
casey..
Casey
Great, thank you for the help.
If I can return the favor, just ask.
jeff, i still need yer snail-mail address, to send the manual to you. have'nt heard from you, or i am just a computer twit, which is entirely possible!!
anyway, it's ready to mail, so, at your conveinence.......
cheers..
casey............. max41254@aol.com.
Casey
Just sent it to your email address.
I was away visiting parents for Mother's day.
good deal, man.
hope your visit was enjoyable, and the folks are sparky and enjoyin life!
I'll pack it up tonight (5/14), and get it out to you tomorrow or Fri.
my schedule is nuts this past week. feast or famine, i guess!
cheers,
casey..
Casey
Had a great time.
Always nice to get a break.
thanks
