The subject of this discussion applies to most all Contractor saws not just Jet. If you’ve ever tilted your blade over and hit your outfeed table, you need to read this. This is not a common sense thing its a hidden danger.
The gearing on the tilt mechanism is of a ratio that will allow you to serously rack the trunion out of alignment if your forget about the motor to extension table clearance and the motor hits the table during the tilting operation. If this happens to you, stop using the saw immediately. The likely hood that the parallelism of the blade is out a seriously dangerous amount is very high.
Checking the parallelism at 0 tilt is not good enough. If you only check it at 0, you can be very unpleasantly informed by flying lumber that it is way out at a 45. This happens because the trunion stretchers are tweaked. Loosening up the four trunion bolts and realinging will not correct this.
To fix a saw that has been damaged in this manner is tedious but it will save the saw and at least one 98.6 deg puddle of body waste fluid on the shop floor.
Here’s how its done….
Preliminary …… DISCONNECT THE POWER TO THE SAW ……….
1. Remove the motor belt guard
2. Lift the motor and remove the belt.
3. Place a board of sufficent length between the motor and the floor so the motor sits level.
4. Remove the electrical connection to the motor.
5. Remove the motor mounting bolts and lift the motor off the bracket.
6. Loosen the two large trunion stretcher nuts at the rear trunion.
7. Loosen all four trunion to table bolts.
8. Vigoursly shake the trunion assembly.
9. Tighten the two large trunion stretcher nuts that you loosened in step six.
10. Raise the blade to its full height at 0 tilt.
11. Place a piece of masking tape at the front of the blade.
12. Grasp the front and rear of the blade and pull it towards you until it stops.
13. Mark the tape on the side of the blade closest to you.
14. Grasp the front and rear of the blade and push it away from you until stops.
15. Mark the tape on the side of the blade furthest from you.
16. Place a mark on the tape that is centered on the two previous marks, (split the difference).
18. Center the front of the blade with the third mark.
19. Tighten one of the front trunion bolts just enough to keep the front trunion at its current location.
20. Place a piece of tape at the rear of the blade.
21. Grasp the motor mount and swing the trunion towads you.
22. Mark the rear tape on side of the blade closest to you.
22. Push the motor mount to the opposite side.
23. Mark the tape on the opposite side of the blade.
24. Place a mark between the two marks and split the difference.
25. Grasp the motor bracket and move the trunion so that the front and rear of the blade are centered on the front and rear center tape marks.
26. Tension the rear trunion bolt on the oposite corner from the front trunion bolt you tensioned earlier.
You are now at zero reference for your table and the trunion is in a relaxed state. You can now dial in the blade paralellism.
1. Use a dial gauge in the miter slot and check the distances along the entire lenght of the blade.
2. Lightly tap the rear trunion with your hand to move it to either side until you are satisfied that the distance variation is within manufactures specifcations or better.
3. Tighten all four trunion bolts.
4. Tilt the blade to 45 deg and check the distance front to rear again. It should be exactly the same as it is at 0 deg. If its not you may have a problem.
5. Return the saw to 0 degrees of tilt.
6. Put the motor back on being careful to align the motor and arbor pulleys.
7. Put the belt back on.
8. Tilt the blade to 45 degrees and check the distances front to rear.
A large change from front to rear is an indication of a cracked trunion that is separating from the weight of the motor. DO NOT USE THE SAW UNTIL IT IS REPLACED. Mine moved -.0009 front to rear which I consider very acceptable and likely just slop in the tilt mechanism.
Steve – in Northern California
Thanks.
Dave I think I qualified the need with this statement:
"The subject of this discussion applies to most all Contractor saws not just Jet. If you've ever tilted your blade over and hit your outfeed table, you need to read this. This is not a common sense thing its a hidden danger"
You are right, Not everybody needs to do this and once your done, the normal method of aligning a blade works just fine. I wrote this two days after I nearly had my head taken off by a pinched piece of wood. I should have seen it earlier when I had wood that seemed to just blow out for no reason at all.
I hadn't heard about the PAL's where did you find them.
I've had several requests to repost this so it seems to be a fairly common problem. Glad to hear that it was at least some help for your Delta too.
Steve - in Northern California
Edited 5/3/2002 1:25:38 PM ET by Steve Schefer
Is there a website where I can look at the (PALS) set-up?
I have the DELTA contractors saw
Ed I'm on a misson, I will find the PAL's and if Dave doesn't get back to us before, I will post the location.Steve - in Northern California
http://www.woodcraft.com/woodcraft/product_family.asp?family_id=895&pf_id=pals
Here ya all go. Woodcraft has them.Steve - in Northern California
tHANKS FOR THE LINK....Too bad they don't show the "PALS" mechanism
Thanks Dave, I think I'll stop by woodcraft on the way home and see if they have them in stock. If not I'll order them off the website. Hey, its Friday and Saturday's a full shop day so I need to buy something new to celebrate!
Thanks DAve, Good describtion of how it works...
PALS are available at In-Line Industries for $19.95, delivered. their website is http://www.in-lineindustries.com. Their catalog has link belts, pulleys, alignment tools, etc.
Hope this helps.
Ken D.
