Forgive me if this has been discussed before ….
Anyone tried the new Starrett dual cut blades that are supposed to cut burr free? Since I’d probably pay more for shipping than the blades themselves, I’m wondering if they live up to their claim.
Denny
Have not Denny, but.... I have tried the Bosch Extra Cleans which I can tell you for fact doesn't leave a burr. Look at the picture below and note the cut-outs in the legs of the small table. I cut them free-hand with a Bosch barrel grip jig-saw and Bosch Extra Clean blades. Those are 1" thick legs of QWWO. I had made a template of MDF to do a final cut on the router table with an over-head bearing bit.
But.. the cut was so smooth I didn't need too. I simply wrapped 120-150-wetted with distilled water and then 180 grit sand-paper around a 1/4" x 1/4" piece of stock and made a few passes inside the cut-out with each. Baby butt smooth. So.. hope that helps as you might save a few bucks on shipping as they are available at your locak Lowe's. Just look for EXTRA CLEAN if you go looking.
Good luck whatever you do...
BTW.. I assume you are referring to cutting wood considering you are on a wood forum and didn't mention metal but... when you say burr I have doubts and you may be reffering to metal?
Sarge..
Woodworkers' Guild of Georgia
Edited 11/5/2009 9:58 am ET by SARGEgrinder47
Wow Sarge - we wrote similar replies at almost the same time!Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
Yes, Sarge, I was referring to wood. Jig saws tend to make a splintery mess of things: a better blade would be a big plus. Thanks.
Denny
Man, I love those Bosch blades. Heard about them on another forum not long after they came out. Make me feel downright happy to pull out the jig saw when necessary.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
The best of the best!
Regards...Sarge..
I use the new Bosch blades and they are great! OK... not as great as the table you post! I love that table. Very nice.. Not a style I make but lovely just the same....
I know some have commented (politely) that the base should be smaller in height.
As I see the shape and size of the top/side stretcher I think the base is fitting. What good is the vertical mass without a good foundation?
Edited 11/7/2009 11:27 am by WillGeorge
Thanks Will...Sarge..
Denny,
I haven't used the Starretts, but the Bosch blades are as good as they get. I like the Bosch Progressor. It looks really aggressive, but will cut plywood cleanly - top and bottom. Which is especially impressive considering my jigsaw is an orange Black and Decker that's older than I am. By the way, I believe that Bosch makes Festool's blades too.
and www.flairwoodwork.spaces.live.com)
The Starretts are supposed to fit ANY saw. Do you know if this is the case with the Bosch? Thanks.
Denny
T 123 X are the Progressors... T 308 B are the Extra Clean. I have both and I thought the Progressors were great.. until I tried the Extra Clean. Both are T shank as most Bosch blades so it depends on what type jig-saw you have.
And I will add that if a Bosch.. the correct orbit and speed is also an important factor as well to get a clean cut. I use Orbit II on the Bosch and 5 speed (6 is highest on that j-s) which is great for harder wood as I mainly use white oak. Yesterday I was cutting some aluminum and used a metal blade and Orbit.. speed 4.
I personally suspect that not many people change the saw's action or speed to match what they are cutting which I find is necessary to improve cuts? I could be wrong but the same people probably won't bother to change from a higher toothed cross-cut blade to a 24 or 20 tooth rip blade to do a ripping operation as they consider it too much trouble. To each his own!
Again.. good luck in your search!
Sarge..
Edited 11/5/2009 11:08 am ET by SARGEgrinder47
Denny,The blades are available with T-shanks or U-shanks. As far as I know, the two types are not interchangeable. Older jigsaws require U-shank blades and the Progressor is only available in U-shank in mixed packages, as far as I've been able to find.Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
