hey all<
I have a general question regarding the taper jig video in this months newsletter. i was trying to figure out while watching the video, what is the purpose for all those holes drilled in the adjustable stop block used tovhold the ends of the stock?? seems to me two holes would be enough to hold it in place, right??
I suspect that they are for other sizes and shapes of legs to be tapered. Lots of holes means you can easily avoid drilling to close to existing holes. Eventually you will end up with swiss cheese in the base, but you should get lots of use before then.
Best regards, Tom.
