Hello,
I am trying to build the cabinet article that is attached. However, I don’t have a router table as well as a dovetail jig nor table saw. However, I do have a couple of routers and a Festool system with a circular saw and MFT table due to space constraint.
Any recommendation of how I can make the joinery for the plywood as in the article he used finger joinery with the table saw.
Is there any other alternative joinery that I can use without the need of a table saw or router table. However, I would like to do the joinery with a router without the router table.
Recommendations are greatly appreciated.
Thank you,
Moataz
Have you considered hand cut dovetails? Or make your own dovetail jig.
Jack
Quick and dirty w/o a lot of hooray and Who Shot John - nailed and glued butt joints and then glueblocks on the inside - segment them if you need to keep them out of the way of planned shelf location.
With a router - a bareface tongue and groove joint. You'll need to reinforce with nails on this one too.
Use epoxy glue under both scenarios.
Edited 7/26/2008 6:03 pm ET by BossCrunk
How about dados and rabbets?
I second the rabbets - I built a version of this cabinet, using rabbets backed by nails. It's completely solid.cheers
jp
Barefaced tongue and groove is way better...
Edited 7/27/2008 5:36 pm ET by BossCrunk
You need to edit your post and remove that pdf attachment. It is copywritten and not nice to post on a free forum where anyone can get it.
