I would like some advise on joining face frames to the cabinet carcass. I’ve tried a few things such as buscuits, glue, glue and brads but i wonder what is the best method. Also how do you join the pieces of your frames, i’ve tried lap joints, dowels and just a little glue any other good options. i think mortise and tennon would work well but might be a little overkill in time and effort. i just bought a pocket rocket pocket hole jig from kregg but havn’t tried it out yet. any advice would be a great help.
Biscuits to locate the top of the frame. Pocket holes down the sides and along the bottom does it for me
Scrit
Glue and clamps
Paul
You can't beat pocket screws for this type of work. I've been using them for the last couple years and they are excellent.
I've been using pocket screws for assembling face frames for about a year now and wouldn't do it any other way. I used to have to glue, clamp, and wait for the glue to dry and now I can screw them together and move directly to assembly.
Most of the time, I attach my faceframes with glue and lots of clamps - and an occasional, unobtrusive, brad. If they will be hidden, I'll use pocket screws.
I glued and nailed my face frames, used a blind nailer so it doesn't show. I used that pocket drill jig with great sucess, you can make strong butt joints at end grain, as well as cross grain.
pocket screws, unless the holes would be visible. Then I nail (18ga 1 1/2") and glue the FF to the carcase. Usually I only have to do this for one finished side; the top and bottom are always pocket screwed and there is usually at least one non-finished side.
Well, I take a little different approach from the previous posters. I have tried plate joinery, pocket hole joinery and butt joint, glue and clamps. I have found that the method which I like best is tongue and groove. I use a set of router bits from CMT - groove in the FF and tongue on the sides - add some glue and clamps and I am finished. I always end up w/ a flush edge at the joint between the FF and side. The reason I use this method is that I dislike seeing pocket holes (or at least knowing that the customer can find them), it eliminates alignment problems and I have large glue surface.
Good Luck!
