Hello,
I am trying to install multiple Shaker Pegboards onto the my wall. The problem is that I cannot buy the right size board to fit the walls total length. I have done some joinery before, but I am not sure what type of method I should use to make a seamless job. If anyone has a suggestion I would greatly appreciate it.
Simple solution is to scarf joint pieces over a stud.
Why don't you buy pegs and make the boards yourself to fit your walls?
David Ring
Both post reasonable to me..
I would make a separating rose bud or whatever at the middle or some even dimension. .. May not be traditional but looks nice!
