I have a house that originally had a single 6′ wide pocket door that slides in from only one side, but sometime in the past the door was taken out and replaced with a 30″ wide pocket door and the door opening was framed in. I am in the process of remodeling and have opened up the wall so the original doorway is there. Only problem is that I cannot buy an off the shelf 6″ wide pocket door and I dont have the time or tools to build one from scratch. I have found some antique french doors that would work great if I combined them into a single pocket door. Has anyone ever joined two doors together to make one larger door? I was thinking about routing a channel on the top of the doors and running a long piece of wood across the top of the doors, adding some biscuits between the two doors and maybe adding smaller strip of wood along the bottom edges. Anyone have any thoughts on the subject.
Your idea has merit. I'd probably rout the groove top and bottom and epoxy in (and screw) metal flat bars, for more strength. Either way, more important is to rout top to bottom and add a spline, glue and clamp.
I think your idea will work. You could use flat iron instead of wood on the bottom, this way the mortise can be shallow. Make sure the edges being joined are square and straight.It may pay to saw joined edges , then biscuit join. Use two layers of biscuits, Keep biscuits at least 1/4" from surfaces.
mike
Be really careful getting your track installed just right. You're doubling (maybe even more than doubling) the width of most pocket doors and that will magnify the effects of any errors in the track installation.
Thank everyone for the response. I think I will look into using the flat metal bar as well.
Pap, the previous posters gave you good advice
IE: steel bands top and bottom.
By using two doors spliced together,
the center stile will be enormous and out of proportion
with a similiar shop built door.
Since both ends of the full sized door
protrudes behind the stops and into the pocket,
you might want to add 3/4' vertical banding
to the left and right stiles?
(Thereby allowing enough material to remove
from the center) (Equally from each door )On such a wide pocket door, two bottom guides
will prove troublesome. Rather a Single centered
bottom guide is more 'Forgiving'. Use top mounted hangers,as opposed to 'Side mount',
as they are hidden from veiw. Stein.
Edited 2/1/2005 1:17 am ET by steinmetz
Stein
I had the same thought in the begining but if the new door is made to look like two doors, eg by an obvious arise, then proportions would be retained.
I agree about the single guide.
Don
Good thoughts. My idea is that when the door is closed, it will look like two doors so I have no problem with the center stiles coming together. I was thinking I would route a very small reveal on one door so they look as if they are still two separate doors that are tightly closed. The original door had one bottom guide, so I will stick with that. Also, I am going to use the origianal 90 year old hardware and rail. The roller mechanism is top hung, so it will be out of view.
I have.. But only about 4.5 feet wide.. I used some heavy glass in frames doors.
I just used dowels, good glue.. There about 10 years now and still works fine.
I did, however, add more top roller assemblies and the track I stiffened up a bit...
