All,
I have been building a shaker style candelstick table (Lebanon, NY design) with a turned center post (3″ about), three flaired legs dovetailed into the post and a 20″ round top, about 7/8″ thick. On the center post the design calls for a 2″ flat area at the top with a 1×3/4″ post that is glued and wedged into a 3/4″ 5×13″ish cleat which attaches to the top on the underside. I modified the top to be 18×20″ rather than round.
Anyhow, I’m applying an oil finish and there is a lot of giggle to the top. It’s solid…right now…but I can see that bumping into it is going to put a lot of stress on that little post…and I’m concerned either the glue will let go or the wood will quickly tear…or something.
I’m thinking about what I can do to help the situation. Perhaps i can take the top off and put three 2″ wood screws on an angle through the cleat into the post?…help share the stress on the joint? Any thoughts?
Those pieces typically had a metal plate on the bottom of the post where the legs attached.
See Bill Hylton's Illustrated Cabinetmaking.
