Has anyone used one of those hand sharpeners that have stones mounted on them at the correct angles to sharpen jointer knives without removing them? If so, how well did they work? It would certainly be convenient not to have to remove, replace and adjust the blades every time they need touched up.
Ed
Never used one of those, but I've sharpened the knives on one of my jointers many times using a router and cup wheel. This method is described by Tage Frid in his book, "Joinery Tools and Techniques." It sounds improbable, but the method works if one takes extreme care in set-up and execution.
Ed,
I ordered one of those last year from Woodworker's Supply. It didn't work at all. My knives were pretty far gone (dull) when I tried it. This item may be intended to put a fresh edge on knives that are just beginning to lose their edge, and it may work for that. But if you expect it to take the place of removing and regrinding knives that are dull, I think you will be disappointed. GP
I tried them from Rockler and was dissappointed. Same ecperience as GP.
The only problem I can see with that it's possible to get the knives
uneven or out of square. I think it's best to remove the knives to
sharpen, than reset them.
Edited 7/15/2002 1:45:35 PM ET by PAULGEER1
Those little doo-dahs are only meant for light touch-ups, as far as I know, not "real" sharpening. What's the difference? Good question, if I do say so myself, LOL.
Thanks Forest Girl. Most everyone so far agrees that those "easy" jointer knife sharpeners don't work very well. I'll save my money and bite the bullet. Just hoped to save some time taking the blades out and getting them adjusted again.
Ed
I've had one for many years now and love it. I think the key is that it is only meant to hone, not sharpen. I never let the blades get too dull, and by touching them up regularly with this device, I am able to avoid for longer periods of time, the removal and sharpening task. They keep a nice even edge across the blade from my experience. But as with anything, dilligence is neccessary.
I know what you mean about saving time. I find that I'm much, much more hesitant to take chances with the jointer knives than I am with the instant-set planer knives.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I've found that after I perfected my method of setting knives, so that now I can do it quite quickly (15-20 min), I'm a lot less inclined to wait untill they're too far gone.
If you're jointer permits, try using an icepick or similar pointed metal. Stick the point under the knife at the ends (between cutter head slot and knife) to quickly raise the knife to the right level.
Dave
Ooo, that sounds like a pretty slick idea. Will keep it in mind when the time comes.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
Well, fools rush in--------
Think of those little diamond grit files which come in sets of four: Coarse, Medium, Fine and Extra Fine. Cost about $26 as I recall it.
I used the "Medium" one, looked at the blades of my old Delta Jointer in the right light with the right glasses on, "caught" the angle of the bevel, ran the same number of strokes at that angle along each blade.
Noticeable improvement in the "feel" of the honed edge and subjectively in the performance on the next series of jointing passes.
If you think a human being can't possibly just fingers/hand/wrist/elbow hold the file at exactly the right angle, I have to agree.
But if you can sharpen your chisels, plane irons, etc. by "freezing" fingers/hand/wrist/elbow at the right angle for the particular tool, why not give it a shot?
William
I make something, sometimes twice, each year.
Edited 7/17/2002 9:07:57 PM ET by William
