Wondered if anyone else has this problem and if so, how it was corrected. Purchased a 6″ delta jointer new. When jointing stock for glueing found that boards are being tapered to the rear. Infeed and outfeed tables appear level and in line at the 0 setting. The blades seem level with the outfeed table. I can’t think of any other tests to run. Any help would be appreciated.
Tapering on the jointer is very common and usually has nothing to do with the setup of the machine and everything to do with technique and expectations.
The first thing to remember is that a jointer has no way to make one edge parallel to another so tapering is a natural result. The planer, which indexes off the opposing side cuts a parallel edge.
See the link below for a story on using a jointer. How you move the wood across it, where and how much pressure is applied and how that pressure is moved are key to using this machine. The jointer looks very simple but using it right takes some practice.
http://www.newwoodworker.com/basic/usejntr.html
Tom Hintz
Because there is always more to learn!
Thanks for the info. I believe the problem was not the machine, but me. Your reference helped considerably.
Tapering is usually the result of the outfeed table being to high with the knives, recheck this height try dropping the outfeed table a couple of thousandths.
> Tapering is usually the result of the outfeed table being to high with the knivesNope. See 36731.2 for the correct information.
Pete
Edited 7/9/2007 6:47 pm ET by PeteBradley
You need to make absolutely certain your knives are set correctly. If they are too high or low relative to the outfeed table will cause either the leading or rear part of the wood to not be jointed true. Suggest you purchase a knife setting jig which makes the setting of the knives relatively painless.
