I have a DJ-20 8″ jointer. After handling by the movers, the beds are out of alighnment . After a little research I learned that the cross bars ar mounted in eccentric bushings held in place by set screws. Any special precautions before I try to re-align? Any ideas on what type of tool to engage the slots on the eccentric bushings? I plan to verify the outfeed table is level across the axis of the cutter bar, then paralle the infeed table to the outfeed.
If it's not too late, one little thing I noticed when tuning up a similar jointer was that there was a set screw under the set screw. They were in the same hole.
