I am having a problem with my Jointer. The problem I am having is that the work piece is high in the centre. I think the problem started after I changed the Knives. I have a 6″ jointer with a total bed length of 46″. Currently the work I am machining is 55″ long. When I change the knives I set them very carefully using a dial caliper and set the height within .001 of the height of the outfeed table. I checked the infeed and outfeed table this morning and the infeed table might be low by only .002 at the very end. I remember reading of this type of problem before but cannot recall what the solution was. As I recall there was a specific reason why a work piece would be bowed or tapered. Any suggestions would be helpful.
Start with the outfeed table set slightly lower than the cutter head and then gradually raise it and take test cuts on two test boards after each adjustment. If the machine doesn't have some more complex problems, you should find a height for the table where the edges of the test two boards will be straight and come together with a tight fit when the boards are placed edge to edge.
John White
