jorgesen cabinet master clamp question
bought my first pair of jorgesen cabinet master 48″ clamps
well, thought i knew how to use a bar clamp
now i have the faces on one of them clamped together and can’t figure out how to get them apart. there is a lever type mechinism in it that right now has minimal movement.
any suggestions?
thanks in advance
bobl Volo Non Voleo
Copied this from a post on Woodnet. The subject has been covered there several times, try a search on Woodnet.
9 times out of 10 you don't need a screwdriver. See if this works:
1) Turn the handle counter-clockwise as far as it will go.
2) With your palm, or a mallet, bump it up (away from the bar).
3) Pull it back.
thanks
just got it apart but will remember this
had the hand screw loose and a little pressure with a pry and it pooped freemy guess right now is that you need to keep that metal lever bwtween the posts, not to close to either end.bobl Volo Non Voleo
bobl
Just a tip I found out after much frustration. When releasing the clamp, screw it counter-clock-wise till it almost will not go any farther. Then lift the wooden handle slightly and it will release easily. Before I figured this out, I spent several minutes trying to release and get the jaws to slide back. Since, I love the Jorgy's. ha..ha..
sarge..jt
