I’m forever doing repairs around “my old House”, in addition to my regular woodworking. I sometimes find situations where no machine can go and a proper cut will solve my problem without having to rip out good materiel. A window sill rot is a good example. I need help on settling on a good hand saw to work such areas. I would like it to cut boldly and have the body not to flex. I’m thinking of one of the Japanese type saws. I would think cross cut, but they also make saws that will cut or rip. Any suggestions!!. Thanks, Michael
Michael.
I've been pretty busy doing some work around the house as well. I live in an old lakeside community where all the houses were built by some guy and his cousin so nothing is straight or square and everything needs to be replaced.
Reason I mention this is because I often have to make small incisions to remove rot and have a few saws that I reach for.
1. For the big stuff that requires precision, I use a reciprocating saw. I actually borrow one from a friend but this is the next power tool I plan to buy. THere are a ton of blade options.
2. Next in line is my Irwin Handsaw. I think you can pick one up at Home Depot. It's a really aggressive cross-cut saw that has a nice rubber handle and isn't so expensive that I'm afraid to use it.
3. Finally, I have two small handsaws. One is a small "keyhole" saw. It has a round handle and a short blade. The only problem with it is that the blade can bend easily. Just last week I found an even cooler keyhole saw from Stanley that takes reciprocating saw blades, so you can swap them out:
http://www.stanleytools.com/default.asp?CATEGORY=SPECIALTY+SAWS&TYPE=PRODUCT&PARTNUMBER=15-275&SDesc=4%2DWAY%26%23153%3B+Keyhole+Saw
Edited 4/30/2008 7:06 am ET by MBerger
Thank you for responding. The more I thought about my question, the dumber I thought it was; however, after reading your respone, it became clear the issue is common. I have basically all the saws you mentioned, and then some. I am happy simply knowing there is not some magic bullet I've missed. Michael
