I am considering buying a crown stapler for, don’t laugh, a “project” that involves carpet….think cat play tree/scratching post. Anyhow, I could just purchase a regular staple gun to do the job(suprisingly I don’t have one) but I have a pancake compressor with brad nailer and finish nailer and wonder if I spent the money on a crown stapler what else is it really useful for. Generally I do bookcases, trimwork(crown moulding, wainscotting), cabinates, bird houses. Is a crown stapler worth buying? Or should I spend my 100 or so dollars on something else. Say clamps.
I bought the porter cable compressor and 3-nailer combo. Never thought I'd use the crown stapler but ended up using it this past weekend installing (plywood) beadboard panels. That's one idea...
Hi,
I used a crown stapler to attach cedar shingles to a shed 5 years ago, it worked great and I've yet to loose any shingles.
Regards...
I use my 1/4" crown stapler pretty often for tacking together jigs, fastening plywood backs, "un-fine" woodworking, etc. I have several manual staplers and never use them (except for a cable tacker - that's one that's worth it's weight in gold).
Mike Hennessy
Pittsburgh, PA
If your doing case goods such as bookcases then you'll love having the crown stapler.
If you shot a back on with a crown stapler it will hold ten times better then shoting a back on with a finish nailer.
Making couter tops is another place that I use mine a lot, making the 1 1/2" ends, I staple them and the holding power is so much better.
Doug
I use mine a fair amount. Basicly any time that I have to nail something thin to something else. For example I usually use 1/8" ply for cabinet backs. If I dont rabbit the backs into the sides I staple them on. If you use finish or brad nails the heads pull through easily, staples dont pull through.
Pardon my spelling,
I use mine to (as others mentioned) attach sheet goods to the backs of casework, to remake or repair lower quality kitchen cabinet drawer boxes (when the originals of melamine covered particle board have broken apart). I will also occasionally use it to refasten center drawer glides in kitchens where they are fastened to the front rail and the nails or screws have pulled loose. I would never use it to attach upholstery, as I've had to remove just a few too many staples done this way.
Another option for the project at hand is a $1.29 box of carpet / upholstery tacks or some carpet adhesive.
It would work, but you might have to cut back on the feed pressure. With carpeting you could easily blow the staple right through the backing.
