I am kind aof new the to woodworking and i seem to be having problems when i clamp up my work. after i have planed and jointed my work i go to clap it up three or four boards to make a panel they dont stay flat. I am sure this is a problem everyone has had at one time or another. Can any one give me some advise as to what the problem is.
Thank you for your help
Trevor Riggs
Missoula Mt
I don't clamp 3-4 boards at once. Some do with a caul, but I find I get better flatness with two at a time.
Use a caul, a 2x2 chunk of wood that goes across the top of the panels and is clamped down to keep them flat.
Don't use too much clamp pressure--this is generally the main thing that I do that causes bow.
You clamps should be in line with the work. If the clamps are too low, e.g., the center of the clamping face is below the center of the edge of the board, the panel will bow up; if the clamp is above center, the panel will bow down. Use a shim to center the clamps to the edge of the panel.
Others will chime in, those are my suggestions.
Scooter
"I may be drunk, but you're crazy, and I'll be sober tomorrow." WC Fields, "Its a Gift" 1934
That make sense. I will give it a try this afternoon
thank you for your time and advice.
Trevor
ME TOO! I only been doing it for about 30 years!
