To honor my grandfather I’m building a decorative display case to hold his war medals and flag out of purpleheart. What finish, if any, will keep the purpleheart from fading?
There are more old drunkards than old doctors. Ben Franklin
Yo. I've heard that purpleheart will lose its color if not finished in a UV-resistant finish. However, I have some purpleheart that's be floating around my shop for about 8 years and it's not changed color at all. Go figure.
Lofton, would I be right in guessing that your shop is lit with florescent lighting...and, like a typical basement shop, remains relatively dark when not in use? I suspect your purpleheart's color is holding up so well, primarily because it isn't getting a lot of UV.
A UV blocking varnish will retard purpleheart from developing it's reddish brown, long term patina, but nothing really does the trick forever. This is bad news if the only reason you're using the wood is for its vivid purple color, but the long term patina it develops is also very attractive.
Very true, Jon. The basement does not get a lot of natural sunlight. However, there is enough light to give cherry a good "sunburn" ("tan lines"?) if I am not careful. But then, I do not have the slighest idea what wavelengths of light affect what types of wood...
Beadvised that the UV protection in the finish wears out. I've heard of people using automotive UV protectant products once or twice a year.John O'Connell - JKO Handcrafted Woodworking
As Jon Arno said, the patina will eventually form and out goes the purple. I solved this dilemma once by shelving the purpleheart and used some philipine mahogany with a purple oil stain. The piece is still the same color after 10 years.
If you use a varnish with UV blockers (or poly) I think it will last long enough, especially if kept indoors like over a mantle. I presume your grandfathr is still alive? I think purpleheart would be the fitting wood to use for such a honored veteran.
Purple heart is pretty open grained so do lots of sanding and use several filler coats. Using high gloss poly, buffing with 0000 steel wool and lastly a power buffer or hand buffing will give a nice finish.
PlaneWood
