Can I cut keyhole slots in 3/4″ wood with small dovetail bit? Todd
Todd,yes, (In a manner of speaking) First you have to plunge cut with a straight bit at least as wide as the dovetail bit and as deep as the dovetail goes. To make a circular dovetail cut, you must make a template with a hole positioned concentricaly with the plunge cut ( allowing the dovetail bit to rotate around it's own axis to form the 'Undercut')
If your router has a 6" base, rout out the template circle's diameter to about 6-1/4"
If you're planing to make a horizontal or vertical slot, use a rectangular template
Or, buy a keyhole bit . Stein.
Edited 12/11/2003 7:04:33 PM ET by steinmetz
Why?
Make one of these...an hour's work or so and will last a couple lifetimes...the tool companies sell the blades:
Keyhole Saw
Oops...you're talking about grooves, eh? Then like above, use the router bit...and for a short dovetail groove like drawer backs I don't bother with the straight bit first.
“When we build, let us think that we build forever. Let it not be for present delight nor for present use alone. Let it be such work as our descendants will thank us for; and let us think...that a time is to come when those (heirlooms) will be held sacred because our hands have touched them, and that men will say, as they look upon the labor and wrought substance of them, ‘See! This our father did for us.’ “ --John Ruskin.
Edited 12/12/2003 1:50:47 PM ET by Bob Smalser
Todd,
Although you can, I'm not sure you really want to - a dovetail bit will remove more material than a keyhole bit, resulting in a weak spot precisely where strength is desirable, and you won't have as good a surface for the screw head to rest against.
Good luck,
Paul
Roger that. and for the jig post....think I'd free hand it.
I went with a metal keyhole inserted in a routed groove. Worked out great. I'll use the dovetail bit for something else and buy a keyhole bit some other time. Thanks for steering me away from the dovetail. Todd
