I am looking for the best finish to use on a kitchen counter around a sink. The counter is MDO painted with a flat alkyd paint. I would like a clear finish that can stand up to typical kitchen use i.e. pots moving around, water, and regular cleaning.
Thanks in advance,
Chris
Hi Chris,
The fact that you're clear coating over a paint makes this a tougher than normal question. There are some very durable clear coats but I don't know which will work with paint (some may not adhere and some may cause it to bubble/peel). The little I do know is that you want a coating that has no color (water-clear) so it will not change the color of your paint.
I'd recommend you contact the folks at targetcoatings.com or your local Sherwin Williams to get a recommendation for a coating that will do the job.
Paul
F'burg, VA
