I’m am building new kitchen cabinet doors that have an arched cathedral rails. I am using templates as a guide on the bandsaw, and then using a top bearing flush cutting router bit to trim them to size. The problem is when I start routing the last half of the arch, I have exprienced tear-out.It’s more like rip out. The bit seems to want to gouge the wood. Is there any thing I can do to stop this from happening.I’m using a 2hp craftmans router
thanks dustcollecter
I would guess that you're getting into something like an "end grain" situation where the bit is tearing at the ends of the wood fibers in the curved section of the rail. A spiral cutting bit may work better since it shears the fibers.
Personally, I make arched rails (and panels) by cutting them on the bandsaw and leaving ~1/16" then using my oscillating spindle sander to sand to the line.
With arches and similar shapes, the bit cuts with the grain on half the shape and against it on the other half. A typical method is to climb cut the half that is tearing out. This has some safety issues since you are moving the router in the direction of the rotation of the bit. The router will want to grab on to the stock and self feed. You eliminate this by taking small bites so that there isn't much 'meat' left behind the bit, always working the bit so that it finishes by cutting into an already cut area. I hope this makes sense. I have a picture of a convex arch. There are some arrows on the piece in dictating grain direction. As the piece is pictured, I start the cut on the very end. The piece will be moved from left to right in a series of small bites.
Another way is to have two flush trim bits, one with a top bearing and one with a bottom. You just flip the piece over. This only works for a flush trim operation. With shapes, you have to climb cut.
Dustcollector,
This doesn't answer your tear-out question but an easier and faster way to cut out the cathedral top rail is to put a guide busing on your router base and use a 1/4" spiral up-cut bit to cut out the rails. The guide busing will follow along the templates that you are using. How deep you cut each pass will be determined by the species of wood you are cutting. Using this method the rails will be perfect.
Kerry
