I build custom sculpted furniture and I need to build a table that can be easily moved. I’m looking for any reference material or sources for different(&unique)methods of knock-down joinery. I’ve never used mechanical fasteners for joints, but i’m open to any and all suggestions. The only criteria I have is that the joint be sturdy and durable.
Thanks for the help
Greg
FWW has a great book on joints and joinery with a article on glueless joints. hope this helps.
*I use a lot of kd assembly, essentially on stuff so big you can't lift it. My choice of fastener is the machine screw (1/4-20, 5/16-18 and 3/8-16) and steel cross dowels plus a joint. Might be T&G, sliding dovetail, mortice and tenon and others. Have the assembly and method of locating dowel center intersect in router jigs book.
*Hey thanks for the replys! The FWW joinery book has some great methods to start playing with. Any ideas on a tapered sliding dovetail going across the grain(regarding wood movement and fastening?
*Outwater Plastics Co. somewhere in New Jersey has a tremendous variety of K.D. hardware and put out one heckuva catalogue. You should be able to get their WATS line number from 800 info. (1-800-555-1212).
*Tapered, sliding dovetails are supposed to run across the grain......... You should have no problem. Think of a shelf being fitted to a case side.
*Haefele has a wide variety of interesting KD hdwe.
