I am an interloper from Cooks Talk Forum and I also have a home woodworking shop.
I have some Hawaiian Koa heartwood that is too short for other projects so I was considering making it into a kitchen chopping block / cutting board (end-grain as the top cutting surface).
First question: Is there enough toxicity to Koa wood for me to be concerned about?
(If I decide to go ahead with the project, I will have a couple follow-up questions regarding glue type, & recommended thickness.)
The Koa has never been chemically treated, & was air-dried years ago.
TIA for any help.
Leftovers
Hmm… I wonder if they meant to write:
¼ tsp of cayenne pepper instead of ¼ lb ?
Oh well – too late to worry about it now !
Just a link I found on the net. I know nothing about this wood. I am sure there are many other links you can find.
http://www.volcanogallery.com/aboutkoa.htm
In pre-western contact times Koa was used to build canoes, spears and paddles. The canoes were carved out of a single tree, which was carefully chosen, spiritually and physically for the purpose. Today Koa is valued for furniture, guitars, boxes, paneling and bowl turning. It is interesting to note that Hawaiians of earlier times did not use it for bowls or platters because of an unpleasant flavor associated with the wood.
Thanks for the link. I had also 'Googled' but found nothing specific as a dire warning about Koa used for food preparation.
I am thinking to make my board 16 x 16 inches, with a finished thickness of 1 1/2 inches. I will router for a thin inlay of birch in a 12 inch circle in the middle. This ends up being a 'target' size when using the board to roll out pie dough.I would use Titebond premium for the glue-ups unless anyone suggests a better product. (It will never be left standing in water - but rinsed with a bleach solution to disinfect after cutting raw meat / poultry.)Knowledgeable folks on the CT forum say it is not really necessary to pre-treat a board with anything & only wipe with olive oil to maintain a shine.
Suggestions for improvement welcome!
Hmm… I wonder if they meant to write: ¼ tsp of cayenne pepper instead of ¼ lb ? Oh well – too late to worry about it now !
Left-overs,
With all due respect, I don't think your idea is such a good. Pie dough is best worked on a cold surface and you don't want to mix cutting boards..but have seperate for meats, fish, chicken, vegs. As long as you considering a birch inlay 12" in diameter, why not make seperate inserts...perhaps plastic for the meats and vegs and cut a 14" square tile into a 12" circle for the pie dough ...which is placed in the freezer for a few minutes before you start. Let me know if you need my home address for this exceptual idea to send me cookies as a thank you...lol
Thanx for the comments.
Actually, my inlay is meant as a 1/8 inch ribbon, just to show when to stop rolling - not a complete inset. (That would be too hard to keep clean.)
It's really a question of technique - I have never found a need to pre-cool & consistently come out with a respectable crust.My present pastry board is a humble vanity sink cut-out from shop-grade birch ply. & a magic marker circle.
Your precaution on mixing different ingredients on the same board is valid. FWIW, plastic boards have been proven to harbor bacteria in knife cuts that can cause problems. It seems that wood does not 'release contaminants' back into new ingredients.
Oh - here are your 'virtual' cookies. (It's a DIY project.) ;-))
http://www.recipezaar.com/recipe/getrecipe.zsp?id=104074
Welcome to Knots, L-O. I did a little searching on this question also, and can only say that if Koa is toxic, there are many, many cutting-board makers/sellers out there who are in trouble! Did you Google for koa "cutting boards" ?
Thanks for the feedback.I did 'google' with the search term as you specified, & realized how pricey some of these pieces can get.I'm going ahead with my board, without concern. (Besides, at age 65, I'm already too old to die young!)Hmm… I wonder if they meant to write: ¼ tsp of cayenne pepper instead of ¼ lb ? Oh well – too late to worry about it now !
